Part Numbers,Specifications Torques Etc
This list can/will be updated as these are identified, I take no responsibility for the accuracy of this report please feel free to add part numbers as you know as well
Indmar engine owners manual ftp://ftp2.indmar.us/Manuals/Operato...s Manual.pdf
Indmar repair manual http://www.bakesonline.com/images/MediaLibrary/Indmar_5.7RepairSpecs.pdf
Other manuals http://www.bakesonline.com/boatinfo.aspx
Oil Filters
AC/Delco PF25
Castrol CM30
Mobil M1- 302
Fram PH30 PH5 also
Napa 1069
Pennzoil PZ3
Penske PN30
Purolator L20049
Motorcraft FL10
Quaker State QS30
WIX 51069
Prop nut torque 30-35 ftlbs
Prop Nut size 1 1/16" for 1 1/8" shafts 1" ? for 1" shafts ?
spark plug 11 ftlbs
shaft coupler bolts 25-30 ftlbsExhaust Manifold Bolt Torque - 18 to 24 ft-lbs
Exhaust Riser Bolt Torque - 18 to 22 ft-lbs
impeller Johnson 812 b
inline fuel filter Napa 3299 Carquest 86299
1/4- 1/2" play on v and serpentine belts
bilge pump Atwood Sahara model S500.
starter parts solenoid for the 4 wire PG260 starter.
Transmission mount bushings rubber 536004. Inboard online $8.61
here are the spark plugs
http://www.summitracing.com/parts/ACF-41-101/ for 340 ext/cat engines
http://www.summitracing.com/parts/ACF-MR43LTS/ for mpfi, carbed engines
