Schweeeettt!!!!!!!!!!!!
Thanks looks great, what's the aluminum channel for? Circulation.
boy, some things never go smooth moddin.
dang stereo head unit wont stay on, will power up and then shuts off rapidly, like it lost power-very strange and not sure what the heck has happened. But i will never find out-disconected it completed and am now using the stereo power switch on the dash to turn on the Exile zld and amps, plugged my cell in to the zld with pandora playing and cranked her up. The factory KIcker speakers sound quite a bit better with the additional power. Love haveing the 4 dials to adjust the sound like a eq. Now i really cant wait to get the sub and towers installed along with the exile interior speakers.
bought a sheet of 3/4 birch plywood to make a sub box, anybody want to give me some measurements to get to the correct size needed. thinks its 1.3 for a sealed box.
Check this, I have three measurements ,
Dusty has one and Ian did one ll different shapes for the same driver.
http://www.moomba.com/msgboard/showt...ghlight=Custom
Nice job! Good looking install - Are you using the dash switch to kill the head unit which then kills the amps?
What sub are you using?Quote:
I have a complete set of drawings including cut sheets for my W6 install --- Using a Qtc = 0.8, I got a net box volume of 1.31 cu. ft. and F3 = 40 hz, Gross volume = 1.4 cu. ft.
I can send you the complete set as a pdf, but that was for my old '02. Don't know if it will help with your install.
Eric.
the head unit is completly removed from my system, it will never be used again as I took and conviscated its power wire and relocated it to the amp, we will only be using a Ipod or pandora. I'm also amazed at how much better it sounds not using the head unit-much cleaner sound.
sub --Exile 12", whole system is Exile, gotta all match ya know
Thanks I'll check out your drawings
