Raise the idle setting.. Problem solved.. :D
The circulation pump doesn't have enough flow & volume of water at idle to supply hot water to the heater (LSV) your theory of adding a Y before raw water will work marginally adding a booster pump will work best ,the engine temp should not drop at idle it should stay in optimal operating temp above 160 which is hot enough for heat .
Forgive me, i am confused on this subject. Where does the extra line coming off the wye go to? Just push in the transmission lockout to raise idle as suggested above.
Inline before the raw water pump.
Post # 4 in this thread.
http://www.moomba.com/msgboard/showt...Heater+fitting
