Can anyone give me any hints on changing the fuel filter - spin on type. Do i need to worry about pressure in the line and gas spilling everywhere when I take the old one off. Thanks
Results 1 to 2 of 2
Thread: Fuel Filter
05-25-2004, 08:40 AM #1
Junior Member
- Aug 2003
- 12
Fuel Filter
05-29-2004, 05:03 AM #2
Senior Member
- Jul 2003
- 340
Replying to Topic 'Fuel Filter'
I can only give you advice for the 310 carb. I don't know how much different the fuel system is for the injected models. I just replaced the fuel pump on mine last week. Sort of a freak occurence, it died over the winter. Anyway, while I was trouble shooting the problem, trying to get the boat started, I pulled the fuel line off the inlet side of the pump on the side of the motor. It was practically dry and only a little fuel would run out of it if I held the line down and out of the drain hole. I found out there is a check valve in the fuel tank that keeps fuel from flowing unless it is under pressure, so you shouldn't get that much flowing out changing the filter. Make sure however you have a jar or can to catch whatever is in the line so it doesn't run into the bilge where it can sit and let off vapors which could cause an explosion hazard.
I'm assuming the injected engines would be similar if the pump is also mounted to the engine. If they have a tank mounted pump, then I don't know what the result would be.
Fuel filter
By drewdwn in forum Service & RepairReplies: 2Last Post: 04-30-2008, 06:33 PM -
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Filter
By beckman2713 in forum Service & RepairReplies: 2Last Post: 11-04-2006, 07:37 PM -
Fuel Filter
By Bobby in forum Boat OwnersReplies: 1Last Post: 09-05-2003, 02:04 PM
