Results 1 to 2 of 2
    Mar 2009
    Default Wiring amp to blue top battery???
    For those of you who are adding an amp to a system with blue tops, how are you wiring. I have 4 posts total. 2 regular and 2 skinny on the top of the battery?
    I have searched the boards and can't find an answer?
    NOR-CAL
    Do you mean a regular post and a small threaded one? If so you can either use a ring terminal on the small threaded one, Or use a regular clamp on the round one. Did the battery come with a wing nut's on the small post ?
