Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
    Mike , How much do one of those throttle boxes cost and does it turn down the volume.
    Cant buy just the Throttle box. Its a Feature on the Exile Harpoon amp im running for my towers.
    No it wont change the volume its strickly for changing how fare the speaker throw sound. At 80 feet up close to the speaker it will be painfull due to the highs and such thats its projecting.
    Turn it to wake surf and the the sound then changes and doesnt project as fare, its like taking it from an HLCD and making it a regular cabin speaker again.
    Oct 2009
    Pacific NW USA
    Default I want a MAGIC KNOB!!!!!!! WHOA!
    Sorry guys, as I have not had much time lately to chime in on here.
    Here's some input for everyone in very plain terms. It sometimes surprises me how people can get confused by all this. The very first thing I'll say is there is no MAGIC KNOB that fixes every audio problem. Keep this in mind while going over this.
    The PAK-LC1 is a very simple and effective tool. In short its a knob that is continuously variable style potentiometer that the captain uses to very the entire audio signal passing thru it. In the real world you'll see this on boats tied into the bass amplifier - to blend the sub overall level or the tower amplifier to reduce volume when a rider is down, etc... as mike mentioned it goes in line with your amplifier and its an easy setup. Only downside is you often times have to run a long rca cable to the helm mounting location. It's not a great thing to be running the low voltage signal around the boat.
    Remote bass knobs - are an entirely different thing. Several mfgs offer an addon knob that looks quite like one of those LC1's but work entirely different. Some boost the bass region of an amplifiers output. On the Exile gear, we use a "twinT" filter circuit that allows the captain to adjust amplifier output across a narrow range of the bass audio spectrum. We do this because we want the amplifier to focus the output energy. This saves power and doesnt make the amplifier work to reproduce un-needed audio frequency. As a side note, amplifier's with built in subsonic filtering do this much the same way. It's really great because all the energy below the port frequency is wasted. Why make the amp work so hard if you dont have to, right?
    Line Drivers - Dont really have remote knobs but play a role here because they sometimes are included in other devices I'll mention in a moment. The bottom line here is they are going to boost up the output of a headunit. Unfortunately, many mfg's are liars when they spec their gear. You really have two choices, buy a headunit that is known to be worthy---kenwood,clarion, alpine marine source units, or keep the unit you have and stick on a line driver. often times i see guys asking me about the biggest meanest amplifier we make and I have to tell them, "hey, start with your headunit bro, or your wasting your money". Liine drivers are pretty cost effect and can be found in 2/3/6 channel versions pretty easily.
    WS420 - My take is its a great device that offers features that sometimes people try to piece together. It's got the line drivers I mentioned, built in EQ's controls and the ability to talk on a remote mic. It will operate like those LC's in every sense but offers a lot more! I think they want 300 or so for it.
    Exile Harpoon - The amp has to very specific knobs built into the amp itself. First a full range level control. Works like those LC's but you dont have to fly RCA's around your boat. It controls the amplifiers input stage sensitivity, allowing you to reduce, blend or shut off all the way the output. I think JL might also offer a full range feature like this as well. The second feature is a unique "marine audio" first. It's called throttle box and it lets the user shape the sound of HLCD's. It doesn't do this with equalization. It uses the inherent HLCD characteristics to map specific audio output goals - CLOSE / NEAR / FAR. It's done with a remote that is continuously variable. Meaning you can make slight adjustments or dramatic ones. Only point that Mike got wrong is that other companies wont be following suit.... We've applied for a patent on this design. It's special and only available in the Harpoon amplifier.
    The bottom line here is that all the items mentioned above are tools for your audio system. When your system grows into a multi amplifier setup, its time to look at these items to help your system reach its full potential.
    Hope this helps.
    -Brian
    Exile Audio
  4. #24
    NorCal
    I thought long and hard about the EQ thing.
    Then i recall something i was taught a long time ago when i became a home Audiophile.
    EQs add distortion to your music, and unless you have an ear for sound, most don't and EQ will only get you into more trouble.
    I decided to not run an EQ. I have a separate volume control for the tower amp, and also a separate volume control for the sub. 2 dials, and a main volume do it all.
    EQs are great if you know what your doing and know how to set them, but most of the time they will add distortion, and most people will set them wrong and over work the amps and speakers with clipping and gains that are too high.
    True, setup is everything with a pre amp. When I installed my EQ I could really hear alot of things (humming mostley) I couldnt before so I went through and did everything over again till the sound cleaned up. Now im really happy with it and running 3 amps, I have alot of control of the way everything sounds indavidually.
    06 Outback V
  5. #25
    Quote Originally Posted by byronkoz View Post
    Which eq do you have running three amps?
    NorCal
    Clarion EQS-746. Also run my Ipod through it.
    06 Outback V
  7. #27
    NorCal
    Not having to use a HU is another advantage of an EQ. I do miss being able to throw on a CD and just use the transom remote so I'm going back to a HU this year.
    06 Outback V
