Results 1 to 5 of 5
    Default Help Wiring Lift Motor to Switch
    I am putting in a new lift and was given a used Magnetek 3/4 hp motor and switch to use to raise boat up and down. I have searched for a wiring diagram and can't seem to find one. The motor has 6 wires coming from it. White, Black, Red, Blue, Orange & Yellow.
    The switch has 5 wires. White, Black, Red, Orange, and Green. I tried matching colors and the motor would only run in one direction. What is the correct way to wire it up?
    Mar 2003
    s.e. washington state
    There may be someone familar with this motor that may help. Can you provide the information on the motor label plate?
    the folks at Lunmar helped me when I wired up mine. here is a link to the wiring diagram and their phone number is on the top right
    http://www.lunmarboatlifts.com/index...lay/page_ID/21
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Here are some pics of the motor and switch. I know the switch is wired correct because it came off a working lift. So the question is related to wiring it to motor
    Angry
    Here are a few more pics. And the last one is for the guys up north that doesn't belive that it snows in Texas, in FREAKING March
