Does anyone out there have a 4 blade prop on a outback? What are the benefits of getting one? Are the benefits worth spending the money?
Results 1 to 2 of 2
Thread: 4 blade prop
11-25-2002, 08:46 PM #1
Junior Member
- Nov 2002
- Atlanta
- 2
4 blade prop
11-26-2002, 12:07 AM #2
Administrator
- Aug 2002
- Maryville, Tn.
- 382
to 4 or not to 4
I am assuming that you have an Outback and not an Outback LS. The 4 blade is designed to give Vdrives more lift in the aft end to help eliminate bow rise and push the keel down, it also helps by being able to move more water upon take-off and not put the motor under more load. However, it is my experience, with the Outback, which is a lighter inboard boat, does very well with the 3 blade. It really depends on what type of skiing that you are doing. Recreationaly speaking, I would stay with 3bl., it will give nice hole shots for skiers and be a performer prop. for tubing, boarding or riding, a 4bl. may get some getting used to at hole shots at first and diminish top end by a mile or 2. If boarding and barefooting are gonna be the big issues here, than the 4bl is da man. When boarding and using ballast or added wt. it will give you a better hole shot for sure, plus with the load added, won't slip. The boarders in the group will like it, it will also help push the nose down to get a little mo' boat in the water for more wake. The big slalom or avg. barefooter will like it to. If possible, demo or borrow one, you make the call. Brian Raymond
3 blade or 4 blade prop?
By schwartzman in forum General ChatReplies: 10Last Post: 01-05-2007, 01:44 PM -
OJ 4 Blade Prop
By jpattigr in forum Moomba ClassifiedsReplies: 2Last Post: 07-05-2005, 06:19 PM -
4-blade prop
By Zihuatanejo in forum General ChatReplies: 2Last Post: 12-26-2004, 01:40 PM -
4 blade Prop
By 99outback in forum Sales & InformationReplies: 4Last Post: 08-24-2003, 05:50 PM -
4 blade vs 3 blade prop
By DOCDRS in forum Boat OwnersReplies: 0Last Post: 09-18-2002, 11:53 PM
