I have a 2004 XLV. I wen to install a set of speakers on the tower and ran into problems. I drilled a hole on the passanger side of the tower to run the wires that matches the ones on the drivers side used for the anchor light. Then I found my problem. When I tried to run the wires into the hole above the joint they got stuck. There is something bloking the inside of the tube about 3 inches above the breakover joint. Has anyone else seen this problem or is it unique to my boat? How do I fix it?
Results 1 to 1 of 1
Thread: XLV Tower Problems
07-08-2004, 09:38 AM #1
Junior Member
- Jun 2004
- 2
XLV Tower Problems
Problems That Will NOT Go Away
By 05mobiusxlv in forum Service & RepairReplies: 5Last Post: 04-17-2006, 11:51 AM -
CD player Problems
By 05mobiusxlv in forum Service & RepairReplies: 3Last Post: 10-02-2005, 12:28 AM -
Tower bolt vibrated loose from tower!
By sailnfast in forum Service & RepairReplies: 6Last Post: 05-20-2005, 02:21 PM -
Tachometer Problems
By wdf in forum Service & RepairReplies: 6Last Post: 08-11-2003, 11:21 AM -
Tower board rack problems
By PuSai in forum Service & RepairReplies: 2Last Post: 06-14-2003, 10:32 PM
