EFI Indmar engine. I can not get gas out of the seperator. The filter is only 3 hours old. I have good pressure going in from the fuel pump.
The dealer said that the seperator is also a regulator and that it needs replaced. I plan to try a filter first.
Does anyone elese have a sugestion.
I'm a little nervous to take to the dealer. They didn't want to give me the time of day on the phone.
Thread: fuel water seperator
07-12-2004, 05:26 PM #1
Junior Member
- Jul 2004
- 2
07-23-2004, 04:27 PM #2
Junior Member
- Jul 2004
- 2
Replying to Topic 'fuel water seperator'
With help from Indmar I found the problem. The secondary high pressure fuel pump corroded apart. The pump is inside the PVC pipe above the water/fuel seperator. The water ate it up over a 4 year time frame.
They also told me not to hook up the water to the cooler so that this does not happen again.
08-04-2004, 07:53 PM #3
Junior Member
- Aug 2004
- 2
just like the oil filter. fill it with fuel before installing it (better start up)
08-04-2004, 07:56 PM #4
Junior Member
- Aug 2004
- 2
wrong topic, sorry!
10-12-2004, 06:40 PM #5
Member
- Feb 2004
- 93
Rainmaker,
I'm in the midst of replacing my Fuel Pump / diagnosing the flow between the fuel and the carbuerator. I was wondering what you meant by "secondary" fuel pump. I only appear to have the single "Carter" fuel pump in my Indmar 350.
I also wondered what you meant when you referred to hooking it up to the water?
Thank you in advance,
Rusten
Fuel/Water Separater
By dtlaine in forum Service & RepairReplies: 4Last Post: 10-19-2007, 08:16 PM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
01 Outback FUEL/WATER problems
By jeffreyala in forum Service & RepairReplies: 18Last Post: 04-17-2006, 10:54 PM -
Fuel Seperator Replacement
By MNFatSack in forum Service & RepairReplies: 1Last Post: 08-04-2004, 07:55 PM -
Water in fuel
By purplepower in forum Service & RepairReplies: 1Last Post: 07-19-2004, 09:05 AM
