I have a 1999 Mobius with a Rad-a-cage tower that was installed aftermarket by the dealer. I have to fold this tower a couple of times a week. I do this by removing the large allen head bolts that connect to the mounting brackets in the front and fold it backwards.
PROBLEM: The bolts are starting to gouge the threads in the tower arm and/or the mounting bracket. Apparently these are aluminum and the bolts are stainless?? Because the bolt threads really load up with the surrounding material but I can eventually force the bolts out by unscrewing them. Then I have to take a small chisel to the threads to clean them up. This leaves the threads on the bolt a little dinged up and more prone to galling the next time they are used. This does not happen every time so not sure what is root cause.
REQUEST: I need to know the specs for the bolts, size, material, strength, so I can get a couple new bolts. Could use some ideas on the best place to buy them. Are there other options? A new tower is not an option at this time.
Any help on this would be greatly appreciated.
Dave
Results 1 to 1 of 1
Thread: Rad-a-cage bolts
07-28-2004, 11:05 PM #1
Rad-a-cage bolts
http://bensonwdby.home.comcast.net/
1999 Mobius - DD - 5.7L Carb - Perfect Pass
Breaking tower bolts
By deeluk in forum Service & RepairReplies: 3Last Post: 06-25-2007, 05:49 PM -
Swim platform mount bolts stripped
By Ghostrider in forum Service & RepairReplies: 4Last Post: 08-02-2006, 12:59 AM -
Loose tower bolts
By clark in forum General ChatReplies: 2Last Post: 09-02-2005, 03:21 PM -
Loose Bolts in Upholstery!!
By mobiusLSV05 in forum Service & RepairReplies: 9Last Post: 07-30-2005, 06:13 PM -
Rad A Cage
By mdrsdr in forum Boat OwnersReplies: 0Last Post: 04-14-2003, 11:06 AM
