Ok my original thought is that it was a fuel injected motor. It is not.
I took the water pump off and the impeller was torn and crumbled... could this be the cause? Installing a new one immediately.
Also could there be a leaky gasket causing it not to idle well? How would I check for this?
Or could the impeller be the source of my idle problem, as the water pump was not turning well...
Results 21 to 22 of 22
Thread: Voltage Low - - HELP!
07-12-2010, 11:49 AM #21
Member
- Jun 2010
- 35
07-13-2010, 05:11 PM #22
Member
- Mar 2005
- Central IL
- 51
I know this may be crazy but I just had it happen to me. Check the voltage witht he same voltmeter on you vehicle battery and see what it is. I have a bad voltmeter to cost me like 10 hours of work before I figured out the voltmeter was bad.
