Page 13 of 39 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 385
  1. #121
    Aug 2008
    Cottage Grove, MN
    Quote Originally Posted by T100 View Post
    Thanks mnpracing,
    So this is what I decided to do to get the water out for the winter. As soon as I started to drill water came flowing out and a lot of it. Water was right to the top. I went with the larger 6" access hole to shop vac the water out.
    Water is still leaking out as I covered up the boat, I'll vacuum more out tomorrow.
    T100 - how thick was the floor where you drilled through? Also, where did you get that deck plate cover? Do you have a link or a part number?
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
  2. #122
    Mar 2003
    s.e. washington state
    Those are marine inspection covers that you can get at most marine supply stores.
  3. #123
    T100, was it holllow under the ski locker floor-no foam?
  4. #124
    Sep 2009
    Vernon BC Canada
    The floor was just over an 1/8 of an inch thick, I bought the marine inspection cover from my local boat shop for $12.00, I can get the number off the box later day, it's in the boat.
    The foam was to the top of the ski locker floor, there was maybe an 1/8 of an inch between the two in some places, maybe because of freezing in the previous year I did not own the boat??
    I drilled through the ski locker, then two depths of the hole saw (very carefully the second depth), I used a utility knife and cut it like a pie to remove the foam each time. I tried to keep it as clean as possible.
    Just as a side note, after taking the majority of the water out, water kept coming from the rear of the boat. The foam is saturated with water and I am not sure it will be completely dry by the time I put her away for the winter. I am going to buy a couple of moisture removers from the boat shop.(Not sure what they are called)
    I can tell you now that a have done this I have peace of mind over the winter !
    Skiers Choice, come on, there is something obviously not right here. My front hull would have been an ice block as big as the entire foam core and more.
    2004 MOBIUS LSV
    2008 Tacoma
  5. #125
    Thanks mnpracing,
    thats a nice clean job. I think this is prob the fix as water may be coming from the back of the boat, bilge into this area
    99 Outback LS. Sold
  6. #126
    St. Albert, Alberta, Canada
    I'd pretty much signed off this forum due to switching seasonal interests, but with a few day break from hockey, thought I'd take a boo.
    All thirteen pages of this thread later:
    1. We have an issue. I have yet to read that it has caused a problem.
    2. Where I live it gets so cold that Celsius meets Farenheit. That ain't no Rodney Dangerfieldizm. Point being that at ambient temperatures lower than thirty below, if this issue was causing freezing damage, you would have heard it on this forum from local folks.
    3. When Grant pulled out 8 gallons and was still only sucking the surface, that's what got my attention. Despite the point in one post about there being some give in areas allowing for expansion, with that amount of water I don't think there would be enough expansion room.
    3. the absence of any info directly from SC injected into this thread suggests:
    A. Yep, it's an issue.
    B. Too risky for them to comment; they are staying out of it.
    4. I appreciate the handiness of many Forum members. I have a 45 yr old special interest car and I expect this kind of chatter (home made remedies to alleviate mfr design flaws) on THAT forum, but this is a modern day issue on assets we are paying tidy sums for.
    Got my interest; will stay tuned. Mine's stowed away for the season, so can't check it.
    Now I am totally sketched to check my ski locker...... This stinks as bad as the Canucks are playing right now!
    (Canucklehead...your Canucks must follow this forum. They're at the top of their division now, with the Oilers at the bottom).
    '07 Outback V
    Ski|Board|Surf|Skate
  7. #127
    Jun 2009
    Victoria BC Canada
    Yeah, that was a pretty good game last night. Go Torres!
    Maybe Skiers Chioce will pull their heads out of their behinds and respond to the issue. Thinking I may sell the boat if this is how they treat loyal customers. I love my Moomba but this is crap.
    2007 Outback V
  8. #128
    Quote Originally Posted by moombabound View Post
    I think this is the jist of Skier's Choice's position - yes, there is water down there but there has been no damage caused by it so it doesn't fall under their structural warranty. I think the water is expanding to fill the void down there and then it pushes up on the ski locker floor since this is obviously the structure put not enough to cause any visible structural damage.
    Not saying I agree, that's just my interpretation from my selling dealer's response and SC's response thru my local dealer.
  9. #129
    Thanks mnpracing,
    Nice work! Just one question - why did you not drill the hole further back in the locker? Seems that would be the low point within the locker so you would want to suck the water from there.
  10. #130
    Sep 2009
    Vernon BC Canada
    I went with that location of the hole because when I looking at the belly of the boat that was the lowest point in the dip of the bow under the boat. As I shop vac-ed the water out, I raised and lowered the bow of the boat to get the flow of the water to move. That is why I noted the water was surprisingly coming from the rear of the boat after the majority of the water was vacuumed out.
    DOCDRS I am considering installing a bilge pump, that is way I went with the 6" access hole.
    2004 MOBIUS LSV
    2008 Tacoma
