Page 26 of 38 FirstFirst ... 16242526272836 ... LastLast
Results 251 to 260 of 380
  1. #251
    I wish I had thought about useing this water in the hull to my advantage-Never thought to use that as a excuse to the wife to upgrade to a 2011 LSV
    13 Mobius LSV
  2. #252
    Feb 2011
    Sylvan Lake, Alberta
    No real advantage to go from the 2010 to the 2011 Moomba LSV, the only upgrade that will be worth while is a XLV or a Supra.
    Rob Snyder...no not the actor!
    2011 Celestial Blue/Black Accent Moomba Mobius LSV, 340HP
  3. #253
    I don't see the advantage of going from your '08 to an '11 either. The ballast system would be better but you have already modded that anyway and a bunch of other stuff is done or on the way. What do you have -- about 110 hrs. on that blue baby?
    Feb 2011
    I agree your 08 is just fine so put a little cream on that nasty itch and enjoy
  5. #255
    130hrs and am thinking about redoing that frankenstein fillin system
    13 Mobius LSV
  6. #256
    Really? I'm thinking about cutting another hole in mine but I really only fill the 400 up front and the surf bag so with two pumps running I'm not sure I really care.
    Yep, I really hate the system I ended up with-pisspoor planing on my part. Been talking with wakemakers a little about the reversible pumps-if I end up with those 1100lb bags I want to be able to surf both sides and will want to do the IBS so would do 4 reverseible pumps.
    13 Mobius LSV
  8. #258
    DO IT! With those monster 1100s you'd need both fast fill and drain. That would be a super clean install too...
  9. #259
    Mathmatically im at 3200gph fill right now, but thats only to fill one surf bag. Its ugly but works for one bag only and thats the problem-I want to be able to surf both sides myself and if someone else wants to surf goofy they cant.
    13 Mobius LSV
  10. #260
    Aug 2010
    Acworth, GA
    Quote Originally Posted by Sea N' Things View Post
    Well guys, just had a GREAT conversation with John at SC, he has assured me that this issue has been fixed from 09 forward. Since 09 they changed the adhesive and fitting process between hull and deck. Guess I'm in the clear but will follow to see if any 09,10 or 11's have problems. Just to be on the safe side I will also be adding an inspection/access plate to keep an eye on things down there.
    Unless the floor in the ski locker starts to sound like sloshing water underneath it, I wouldn't add a hole where water could then get in. You could introduce the problem yourself, and that would be bad. If it is sealed as they say on the 09 and newer hulls, I wouldn't cut an access hole. But that's just me
    Kraig - 2010 Outback V
