Even if you have trapped water your center drain will be dry....like mine. If you want to know if there is water open the ski locker, stand up on the floor ( in the ski locker) put your feet as forward as possible and jump...you will hear the water.
My dealer was supposed to call me back for that problem but I m still waiting........................
Results 331 to 340 of 354
10-02-2012, 07:12 PM #331
Mobius LSV 2011
10-03-2012, 03:05 AM #332
I only have 1 drain....at the rear of the boat, no centre drain.
The water is stuck in there with no way to escape....I might have a look this weekend....but I don't want to spend days at it.Dave Longbotham
Minsterworth Waterski Club
River Severn
England
U.K.
Mobius V 2000
d.longbotham@virgin.net
http://vimeo.com/30891897
10-03-2012, 07:51 AM #333
Senior Member
- Aug 2011
- Newnan, GA
- 110
10-03-2012, 06:08 PM #334
Doesn't your basement locker have a drain that goes back to the bilge area? I get water in the basement regularly. Have ran the boat plowing nose high for a short ride to drain it, then put a cork in it before slowing back down. At home on the trailer I will lower the jack and the nose of the boat as far as it will got and let the water run in there intentionally, then vac it out with my Tsunami handheld. Or drive up and park on a hill for a few min while everything drains out the back.
2001 MobiusV
10-04-2012, 03:12 AM #335
Drain
Sorry, yes, I have a hole running from the front ski locker to the rear engine compartment.
I don't have an actual drain plug in the centre of the boat (like some Mastercrafts).
I actually blocked up my hole from the front ski locker to the rear compartment, as it was always wet in the ski locker......
Now its my dry area, with a fatsac in place....(i say dry, but whenever it rains heavy, the rainwater from the front section of the cover seeps in to the front seating area, and down into the ski locker. (as my ski locker has no 'roof')Dave Longbotham
River Severn
England
U.K.
Mobius V 2000
10-16-2012, 08:52 PM #336
For those who put a deck plate in the ski locker did you put it in the front, in th middle or in the rear of the locker? I will have to do this but I don't know where to drill the hole
Mobius LSV 2011
10-16-2012, 09:51 PM #337
I put three deck plates in the ski locker (front, middle and rear). I found that the foam restricted the water from flowing back to the deepest point below the ski locker floor. I started with the first hole as far back to the stern as I could, but when I sucked the water out, there was still water sloshing further up front. I was amazed at how much water I got out of there each time I drilled a new access hole.
10-16-2012, 10:07 PM #338
Mobius LSV 2011
10-17-2012, 12:20 AM #339
I do find water there more than I would like and it's not always cause I dip the bow. I struggle to make sense of it, but maybe I get some leakage from my ski locker bag? The other thought is that my bow lights (dock lights) are the culprit, but I usually don't roll that deep.
I used 4 or 5" plates, I don't remember exactly. I actually have Sahara pumps in two of the holes to auto suck out the water, so check the dimensions on those and that might tell you what I have, as the pumps fit in the opening, no problem.
No stringer down there at all.'08 Mobius LSV, Mods- 1100 lb Rear Sacs, IBS Sac, Center 400 Sac, Dedicated thru-hull intakes and pumps per sac, SeaDek One Piece Mica over Black Roo, EZ Net Cargo Nets, Swivel Drivers Seat, Hot Water Shower, Hinged Wind Block, Bow Cushion Adapter Plate for Drink Holders Access, etc, etc.
10-17-2012, 03:48 PM #340
Today I made a hole in the rear of the floor like the dealer suggest. Surprise.....no water there....everything s dry. So I made a hole in the front an a lot of water ( smelling bad) starts to get out. I ve shop vac 26 liters of water there. So now I think that something restricted the water from going in the back.....just foam or somethin else? Stringer?
Mobius LSV 2011
