Page 36 of 36 FirstFirst ... 26343536
Results 351 to 354 of 354
  1. #351
    ideal loction would be at the bottom of the drop portion on the keel. my 2013 center drain is located inbetween the skegs which is higher than that the drop keel portion, so that would not really solve the issue of water trapped in the keel
    13 Mobius LSV
  2. #352
    Feb 2012
    Murrieta, CA (SoCal)
    Precisely. I think its a good idea but I don't want to do it first!
    EDIT: I should say I think the drain between the skegs is a good spot as well. That is the low point in the bilge/fuel tank area when on the trailer. I understand there is a semi-permeable barrier (partially sealed bulkhead??) between that area and the area of the drop keel. I'd say if a guy was going to get excited about adding drain plugs he would want to add both. Might even help minimize the water under the locker.
    - John
    2002 Outback LSV
  3. #353
    Default Water trapped between hull and ski locker subfloor
    Quote Originally Posted by Gabbyg88 View Post
    I bought a used 2007 Outback V and was concerned when I read this post. Unfortunately, the boat sat outside uncovered on the dealers lot for about 2months until I bought it. I think thats where my water came from, but could be wrong. I pulled the sac and the mat from the ski locker and noticed I had water seeping up throughout the floor. I called Skier Choice and they told me to drill 5" hole, pull the insulation, dry it, once dry use spray foam to fill the hole, replace the fiberglass piece and fiberglass it back in. I don't want to do that because I won't know if water is getting back under the ski locker. I am going to re-fiberglass the whole ski locker and seal it. Then I am going to install a 5" water tight deck plate from Overton's. I think my water is coming down through the floor of ski locker, the fiberglass seems brittle in spots. I hope this correct this issue. SC was very nice and helpful, but would not admit this is known issue with this boat.
    Gabby. Not sure I would waste my time glassing the floor, the water can come in from a void in the bow tip at the front of the locker. Sc knows about this issue. I did the deck plate and just drained it regularly .
    Jan 2013
    PA
    Joe - thanks for the advice. I been thinking about it alot and I have decided to just put down a layer of 6oz. fiberglass mat on the floor of the ski locker. I am not going to try and re-fiberglass the whole ski locker and seal it. I agree with you it will be a waste of time and money trying to re-fiberglass the whole ski locker. The only reason I am laying fiberglass on the floor is for strength and will only be doing the area I reach, I don't like when I stepped into the locker I heard cracking.
    2007 Moomba Outback V
