Good idea. That would look good as long as it's done right. That's the way SC did the access panel for the second drain plug under the gas tank on the newer LSV's except that it has a ring pull on it and it's not screwed down but that's because it has to be accessed frequently.
Although, I'm not sure the routed recessed lip would be strong enough. Might have to screw in some flat stock of aluminum instead. And that way, you could just use the piece that you cut out as the cover plate.
Results 101 to 110 of 354
11-01-2010, 04:27 PM #101
11-01-2010, 05:01 PM #102
If i'm not mistaken that's exactly how the current floor access panels are now, just a recessed lip in the floor. I think i saw a pic somewhere but can't remember. Because it doesn't have to be that big (6x6 or 8x
a 1/4" deep x 1/4" wide route to accomodate an 1/8" plate plus carpet and it should be flush.
11-01-2010, 05:08 PM #103
I blew up mpnracings pic here. You can see the thickness of the floor, it's plenty thick to accomodate that idea. Looks to be 3/4"-1" material.
11-01-2010, 05:32 PM #104
Just great, now when i get home im going to have to get up in there and check it out as its been towed thru monsoon rains, sat in monsoon rain sorms while out boating-this is florida and a hour later the sun could be back out, had water over the bow-more than once, and had a faulty drain pump on the 750lb bag so i just drained it in the bilge.
I am a little suprised at no response from SC.
13 Mobius LSV
11-01-2010, 05:42 PM #105
11-01-2010, 05:45 PM #106
Senior Member
- Aug 2008
- Cottage Grove, MN
- 697
For the thickness of the floor where the deck plate is, I'll measure it tonight. My guess at the time was < 1/2".
As for the access port over the gas tank in the 2011's, it's an aluminum square the same thickness as the aluminum floor covers. It's roughly 1" thick (plate welded to square tubing), and there is bracing where this deck cover sits so that it is flush with the floor. It just pressure fits from the carpet glued to the top and sides of the roughly 6" X 6" cover.2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
11-01-2010, 06:46 PM #107
11-01-2010, 07:03 PM #108
Yeah that's the pic i remembered, thanks Al. I'm sure with a little bit more thought this could easily be done and still provide adequate support.
So I was thinking a deck plate type setup with an aluminum frame that sits in the hole, floor routed slightly to sit flush and under carpet. And instead of the deck plate door, an aluminum recessed cover (carpeted) sitting flush also. Support and strength. hmmmm.
I know someone who welds and fabs, i may have to talk with him about fabbing a frame up to see.2007 Mobius LSV
11-01-2010, 07:51 PM #109
11-01-2010, 08:10 PM #110
Add me to the list
Pulled the ballast bag out of the ski locker-the bag was wet on the bottom yet when I put the boat away about a month and half ago it was dry. Standing/bouncing on the ski locker floor I can hear air escaping--sounds like its weezing really. When kneeling inbetween the bow seats and sticking my head down in there and wiggleing the boat I can hear it sloshing underneath.
FYI- 2 weeks ago I filled the gas tank with gas for its winter hibernation, so im 99% sure its not what im hearing.
Looking up forwards it looks like the floor and hull have enough sealant so im thinking its getting someplace else.
I had the floor out last year when i was adding my depth finder and there was standing water under the gas tank-just thought I would mention that
13 Mobius LSV
