Hi there! I'm stoked as I just bought one of the last two '04 LSVs off the line:
Tri-Color Patter (black with graphite)
SS Rub Rail
Rad a Cage tower
Bertha Ballast System (3 bag)
Wake Plate
Water Strainer
320 HP TBI
4 Blade SS Upgrade
Kenwood Deck with 6 speakers and transom remote
Boat Cover
Dual Tandem Axle Trailer with Disk Brakes
Swing Away Tongue
I'm stuck waiting until next spring until the weather in Michigan warms up before I can use it, but am curious if anyone else has the Tri-Color scheme and if so, how you care for the black gelcoat? I want to prevent water spotting as much as possible and was curious if anyone had any luck with particular polishes/waxes? If so, let me know. Also, any other suggestions you have on preventing damage and/or taking care of the boat would be appreciated! Thanks!
11-03-2004, 06:45 PM #1
Junior Member
- Nov 2004
- 25
Care for new black/graphite '04 Mobius LSV?
11-30-2004, 01:40 AM #2
Senior Member
- Jul 2003
- 340
Replying to Topic 'Care for new black/graphite '04 Mobius LS
test
11-30-2004, 01:44 AM #3
Senior Member
- Jul 2003
- 340
I use a wax called Zaino. Downside is that it's a little expensive and you have to order it from zainobros.com. By far the best car wax I've ever used, long lasting, easy on and off. It's been doing a great job on my boat as well.
The other big tip I can give you it to wax everything you don't want to get water spots on, glass included. Go get one of those synthetic chamois from Wal Mart and keep it in the boat. Wipe the boat down every time you take it out of the water. When the chamois gets dirty, throw it in the washing machine. This has worked great for me, hope it helps.
01-28-2005, 07:28 PM #4
In my opinion it comes down to work mostly and it is less about what kind. I use Maguires wax and they have different levels in case you do get some water spots or damage. I start with the wax number that removes the water spots or scratches and work my way up.
I have a black boat and it is without any water spots and I have spent a week in Lake Shasta which usually gives permanent water spots.
After each use I wipe it down, and if I am spending long periods in the water I wipe it down maybe twice a day or at least once. I used vinegar and water when I was in Shasta to keep water spots off.
That is all
Engine Care
By Engine Nut in forum Service & RepairReplies: 3Last Post: 08-14-2006, 02:46 PM -
Graphite Inpregnated Cord Pros and Cons
By zabooda in forum Sales & InformationReplies: 3Last Post: 08-13-2006, 06:40 AM -
Bottom Care
By beckman2713 in forum General ChatReplies: 10Last Post: 05-25-2006, 01:51 PM -
babes boat care
By qb12 in forum General ChatReplies: 1Last Post: 04-21-2006, 03:31 PM -
Saltwater brackish water engine care
By chpprpilot in forum General ChatReplies: 5Last Post: 04-12-2005, 03:52 PM
