Results 1 to 3 of 3
    Jul 2010
    Dothan AL
    Default will polk db651 fit
    ok so this is my first post, however i have gained alotttttt of knowledge from this forum. My ? is wil the polk db 651's fit in my 05 mobius ls without a gap from where the cheap boss speakers were. i seen a post about ppl having to cut a plastic ring to fill the space around the rim. i have also seen where they are direct replacement fits. but none of the post were about an 05 mobius ls. Thanks in advance for any input.
    Dallas, TX
    The Polk speaker grills are barely under 7" O.D. just like most contemporary 6.5" coaxials. So if the previous speaker had a larger grill diameter that leaves an indentation around the perimeter then you will face that with just about every coaxial.
    Over time heat will relieve much of the cosmetic indentation.
    When we've made a dress ring from thin acrylic to conceal the outer mark, we usually pick a color that corresponds with piping in the vinyl. It adds a nice touch.
    If for some reason the opening was oversized then a split ring set can be inserted through the opening and pre-attached to the backside. The mounting hardware is concealed by the speaker. This ring set once in place provides the structure to mount a speaker with a smaller hole pattern.
    As for '05, I don't recall having an issue. But if you do then the fix is easy.
    Earmark Marine
    Jul 2010
    Dothan AL
    thanks, sounds like i need to order me some polks
