Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
    Feb 2010
    Canton, Ga / Lake Lanier
    Installed the radio tonight. Both driver and transom remotes work. I was not able to test if it will change tracks on the i-pod but I will check that this weekend.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Dothan AL
    Make sure the play mode on the 440u is in hands off mode and u can skip tracks with the remote . If the ipod is hooked up to the usb
    E4 yes tape the area up with a couple layers of tape, this helps stop chipping and the bit wont walk as easy. Always start in reverse when drilling and use a sharp bit. You can switch to forward once your threw the gell coat but most of the time i just drill it in reverse.
  4. #24
    Sep 2012
    Chattanooga, TN
    Sorry to resurrect an old thread, but I figured that this was the best place for this info..
    The Kenwood KDC-352U works just fine with the Aeware remote. I would be willing to bet that the following work too, which share an instruction manual w/ the 352U:
    KDC-X396
    KDC-252U
    KDC-202U
    KDC-MP252U
    KDC-MP152U
    KMR-350U
    2005 Moomba Mobius LSV
