Results 31 to 40 of 40
Thread: LED accents?
  1. #31
    Jun 2009
    Victoria BC Canada
    Quote Originally Posted by ChrisK View Post
    Canuckle those are just two of the Oznium flood lights?! I'm thinking those look better than the spotlights I just installed... I might have to go 2 of each
    Nuh uh, those are the VisionX lights. The same as Newty put on the back of his boat but X2.
    http://www.visionxusa.com/LED-Subaqu...2eeefbffaae860
    Super easy to install and wire in.
    2007 Outback V
  2. #32
    Jun 2011
    Hillsboro, Oregon
    Talked to Oznium tonight. My transom lights are still on back order. I was told last week they would ship Friday. Now I am being told then shipment should come in Thursday this week. When I placed the order on 6/18 I was told the back order would be a week. At this point just getting a little frustrated at the waiting.
    Derek & Poppy
    2010 Mobius LSV Sandrock/Fossil
    Gravity III ballast, wake plate, Z5
  3. #33
    Jun 2011
    Hillsboro, Oregon
    Just an update. I received everything finally this week. Planning on using the 3M 5200 adhesive/sealant for the drill through and screws on the transom mount lights, so probably won't be installing them until Sunday night (since it looks like summer will arrive here in Oregon this weekend).
    Derek & Poppy
  4. #34
    Apr 2010
    moncton, nb canada
    They suggest to use the 4200. the other 5200 is too strong and if ever one light burn down or something you wont be able to remove them and change them. When I received the instruction for my transom light. It was written in huge Red bold letters. " DO NOT USE 3M 5200". Hope its not too late for you.
  5. #35
    Jun 2011
    Hillsboro, Oregon
    Thanks! It's not too late. I won't be putting them in until next weekend. Have a business trip coming up and the boat will be sitting for a few days, so all will have a chance to cure out.
    I had read on some of the other posts (Newty) that 5200 was used. There was one post with a debate back and forth. I do have a tube of 5200, but will to pick up some 4200.
    Derek & Poppy
  6. #36
    Aug 2009
    Montana
    Either will work but I used 4200 for the simple fact that "IF" i have to remove it I should be able to. Newty did use 5200 but suggested and would use 4200 next time for the reasons stated already.
    good luck with the install.
  7. #37
    Dixon, IL
    Millerda68, did you ever have a chance to install your lights? Any pics?
  8. #38
    Apr 2007
    Las Vegas, Nevada
    I have a set of Abyss light. I love them. very bright. The only thing I hated was drilling a hole in the boat to run the wire. Make sure you counter sink the screw holes. You do not want the gelcoat the chip. I ran the wire up to one of my accessory switches. works awesome.
  9. #39
    Jun 2011
    Hillsboro, Oregon
    Yes, finally got them hooked up this past weekend, but have been on the road for work, so have not had a chance to test the transom lights yet. Will be on the road until next week, so hoping over the weekend once I get home I can get them in the water at night and see how they look.
    Derek & Poppy
  10. #40
    Dixon, IL
    Sounds good, I'm anxious to see them. You just went with a couple of the oznium flood lights right?
