well no point in posting pictures......... my platform broke off just the same as the brackets in the earlier posts. They are at the welders right now getting fixed. poor design by moomba, why are the brackets not made out of stainless steel, then you would have no problems.
Did we get an answer on how to tighten the bracket attached to the boat?? I could not figure it out! Again bad design!!!
Results 81 to 86 of 86
09-06-2011, 12:17 PM #81
Senior Member
- Apr 2010
- saskatchewan, canada
- 279
2005 Mobius LSV
wakeplate, perfect pass,
Fuel Injected
1433 acme prop
09-06-2011, 12:35 PM #82
Senior Member
- Aug 2008
- Cottage Grove, MN
- 696
did the bracket on the transom break, or the bracket on the platform? Also, are you saying that when tightening the bottom bolts on the transom brackets that you can't get them to tighten? The top bolts should be accessible from inside the boat, you might have to pull the carpet back from the wall of the transom.
2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
09-06-2011, 12:41 PM #83
Senior Member
- Apr 2010
- 279
The bracket on the swim platform broke just like in the pictures, when i took it off I noticed the boat bracket was a little loose so I tried to tighten it and the screws just turn. I didnt realize that you can get at them from the inside of the boat, I thought they were glassed in.
2005 Mobius LSV
Fuel Injected
1433 acme prop
09-06-2011, 01:32 PM #84
Senior Member
- Aug 2008
- Cottage Grove, MN
- 696
09-06-2011, 01:37 PM #85
Senior Member
- Apr 2010
- 279
Do they just have a nut on them? I sure hope I can get at them!
Anybody out there have a 05 lsv and had to tighten the bolts on the swim platform boat bracket???2005 Mobius LSV
Fuel Injected
1433 acme prop
09-06-2011, 02:02 PM #86
Senior Member
- Aug 2008
- Cottage Grove, MN
- 696
