Page 9 of 9 FirstFirst ... 789
Results 81 to 86 of 86
  1. #81
    Apr 2010
    saskatchewan, canada
    well no point in posting pictures......... my platform broke off just the same as the brackets in the earlier posts. They are at the welders right now getting fixed. poor design by moomba, why are the brackets not made out of stainless steel, then you would have no problems.
    Did we get an answer on how to tighten the bracket attached to the boat?? I could not figure it out! Again bad design!!!
    2005 Mobius LSV
    wakeplate, perfect pass,
    Fuel Injected
    1433 acme prop
  2. #82
    Aug 2008
    Cottage Grove, MN
    Quote Originally Posted by saskie99 View Post
    did the bracket on the transom break, or the bracket on the platform? Also, are you saying that when tightening the bottom bolts on the transom brackets that you can't get them to tighten? The top bolts should be accessible from inside the boat, you might have to pull the carpet back from the wall of the transom.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
  3. #83
    Apr 2010
    The bracket on the swim platform broke just like in the pictures, when i took it off I noticed the boat bracket was a little loose so I tried to tighten it and the screws just turn. I didnt realize that you can get at them from the inside of the boat, I thought they were glassed in.
    2005 Mobius LSV
    Fuel Injected
    1433 acme prop
  4. #84
    Aug 2008
    Cottage Grove, MN
    on my boat, only the top bolts are accessible, the bottom bolts are below the level of the floor.
    2008 LSV - Gone
    2013 other brand
  5. #85
    Apr 2010
    Do they just have a nut on them? I sure hope I can get at them!
    Anybody out there have a 05 lsv and had to tighten the bolts on the swim platform boat bracket???
    2005 Mobius LSV
    Fuel Injected
    1433 acme prop
  6. #86
    Aug 2008
    Cottage Grove, MN
    yes, the ones that are accessible have a fender washer and a nyloc on them.
    2008 LSV - Gone
    2013 other brand
