Question about wiring the speakers in parallel. Do you just jump from the +/- from the one speaker to the other?
Anyone have a diagram?
Thanks in advance.
Results 11 to 20 of 23
05-12-2011, 02:39 PM #11
2007 Outback V
05-12-2011, 02:54 PM #12
05-12-2011, 04:16 PM #13
Yes. Run the speaker wires from the left channel of your two channel amp and connect them to the first speaker on the port side. Then take another speaker wire and connect the "+" from the first speaker to the "+" of the second port side speaker and the "-" to the "-". Wiring two 4 ohm speakers in this manner (parallel) presents a 2 ohm load to your amp. If using the Exile Harpoon, this means each speaker will get up to 250W RMS.
AlAl
06-17-2011, 11:51 AM #14
Hi Al,
Can you tell me how far off of center did you drill the holes for the speakers on the underside of the tower? I know you said just off center but how far? Can you give me an approximate measurement?2011 President's Trophy - Check
2007 Outback V
06-17-2011, 02:09 PM #15
06-17-2011, 02:22 PM #16
I can't remember what size drill bit I used but nothing too huge. I drilled the holes directly on the bottom of the tube and I still had plenty of freedom to point the speaker up or down quite a ways without pinching the wire. So I wouldn't sweat it.
06-17-2011, 07:35 PM #17
2007 Outback V
06-19-2011, 10:16 PM #18
al this couldn't have come at a better time!!!!! I'll be mounting up my sxt's this week!
Thanks for this!
Geoff2005 Mobius LSV, PP Stargazer, GIII Ballast with 1100"s in the rear lockers and 500 in the floor, Ipod to Exile ZLD, 4 XM7's run by a harpoon,
SX65C in cabin on a 800.4 and a JL Audio 12" sub run off a JL m1400
2012 Dodge Ram 1500 Sport, all grey with upgraded kicker stereo from mopar
06-20-2011, 12:11 AM #19
Had to abort the installation this weekend as the clamps I got from exile are too big. Not sure what to do about it other than let Brian know and wait to hear back.
Worked on my ballast project instead. Will post pictures in a separate email.2011 President's Trophy - Check
2007 Outback V
06-20-2011, 10:18 AM #20
You will need to drill 3/8 holes for mounting the clamps, i would suggest 1/2 thought as this will give you more wiggle room to move the clamps to the adjustment you need.
As for the clamps theres 2 styles, Normal which are large and on an OBV tower wont tighten down, then there are the OBV style clamps there the bottom of the clamps is machined off to allow it to clamp.
When Exile ships the speakers they are sopposed to manualy change your clamps if you have this tower. I would call Brian and explain what happaned. There has been a couple speakers sent out like this since its a manual swap and not a preboxed speaker setup for the OBV tower diameter.Malo <--- Means--Evil or Mean One. This explains a lot.
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
