What is the best option for an inexpensive balast pump. Not a total piece of junk but nothing crazy either. Is there a way for me to run the fill and the drain off the same pump as well? Thank you.
Results 1 to 5 of 5
Thread: Ballast pump question.
06-09-2011, 02:36 PM #1
Junior Member
- Mar 2011
- Canandaigua NY
- 15
06-09-2011, 02:44 PM #2
Tsunami 1200.
06-09-2011, 02:57 PM #3
Yep. http://www.wakemakers.com/fly-high-tsunami-pump.html
Or are you trying to automate your ballast? If so the T1200 is still cheap, easy, and fast. But you'll need one to fill and one to drain.
06-10-2011, 11:54 AM #4
Yeah and the T800 is even cheaper, depending on how much weight you're pumping, you could just do the 800's. I fill up 3 bags in less than 10 minutes with just two of them. Plus I maybe remember hearing something about the 1200's not having 3/4" fittings on them? 3/4" makes installs very easy.
06-10-2011, 01:59 PM #5
wakemakers must have found someone to produce this , because they now have one.
http://www.wakemakers.com/attwood-12...k-connect.html
12.95 is a little spendy, guess there is some r&D involved....A Day at the Lake...Priceless
