I just bought a new 04 mob lsv, yesterday I went out on the lake to get some break-in hours in and everything worked great except for the stock front ballast. It would fill but I cant get it to empty. The back two tanks would empty fine, but the front one will not even make a sound. Anybody have any advise, or should I just have the dealer deal with it?
Results 1 to 10 of 12
Thread: 04 LSV Ballast problem
03-24-2005, 06:37 PM #1
Junior Member
- Feb 2005
- 6
03-24-2005, 09:49 PM #2
Senior Member
- Mar 2005
- 109
Replying to Topic '04 LSV Ballast problem'
Seems to me I remember something about a switch to go from the front tank to the rear ones. Without the switch in a certain position the front tank wouldn't fill /empty--one pump controls all three tanks. Good Luck, keep us informed my 05 is ready for delivery soon!
03-24-2005, 10:50 PM #3
Administrator
- Aug 2002
- Maryville, Tn.
- 382
There is a ballast fuse panel under the starboard dash, this holds fuses for the fill pump/solenoids and the 3 drain pumps. Visually inspect the front drain fuse, if it is blown, insert another fuse of the same amperage, if the fuse blows again, thier may be some issues at hand, and an appointment at your dealer is suggested. I hope this helps, keep us posted. Brian Raymond
03-25-2005, 05:12 PM #4
Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
TK42
Each bag has its own empty pump.Check the connection and the fuse first.Also Check to see if the light on the switch comes on when you go to the empty side.If not the wire might be off behind the switch panel.Do your self a favor to and take your bag out of the front locker.Hold the door open with the snap strap.Look up under the the top side of the locker with a flahlight.My 04 Mobius LSV had several long sheet metal scews sticking into the compartment that could rupture the bag when full.Just cut them back and put some RTV over the cut down screw.If yours does not have the screws then your all set.Just thought I would mention it because mine did.
John
03-29-2005, 06:44 PM #5
Senior Member
- Mar 2005
- NC
- 115
I was having a similar problem and realized that the sack had been plumbed incorrectly. The fillup connection was on the bottom so had no problem filling the sack. The drainage tube however was on the top so couldnt get any water out of the bag. I switched the connections and it worked great. Not sure why it was backwards and may be different from what you are experiencing but maybe will help someone else...
03-29-2005, 07:10 PM #6
Senior Member
- Mar 2004
- 213
Mine also were plumbed backwards.But according to my dealer he tested everything on the lake and it all worked good.I hate when dealers lie.
John
04-22-2005, 02:40 PM #7
Member
- Jan 2005
- 60
Just checked my ballast bag and it still has a few gallons even though I had the pump on to empty for quite a while. Is this normal to have a residual amount of water in the bag or should it completely empty. I plan to take it out tomorrow and will look a little closer at it then. Also, I notice it takes several minutes to fill. I only have the standard center ballast on my 05 Mobius LSV.
Will
04-22-2005, 05:22 PM #8
Member
- Apr 2003
- Minnesota
- 84
Will,
When you empty your bag do you physically lift the front of the bag to get the water to flow back towards the pump? If you just run the pump and don't move the bag you will have some water stay in the bag. If you really want to get it empty you need to pull the front of the bag out of the locker and just hold it in the air to get the water towards the pump and then you can just tip the bag back and forth until it's all out. If you're worried about it freezing in the spring or fall (we live in MN) or when you want to store it for a while you can just unscrew the fittings when it's empty to get the last bit of water out.
04-23-2005, 12:23 PM #9
Senior Member
- Mar 2005
- 109
New guy waiting on boat, will the ballast tanks come completely out of the boat when empty. In the fall I'd like to remove them??
04-23-2005, 09:38 PM #10
Senior Member
- Mar 2004
- 213
Yes,they are not tanks,they are bags.
John
Yet Another Problem w/ 07 XLV GG
By bradcraig78 in forum Service & RepairReplies: 5Last Post: 05-15-2007, 06:01 PM -
don't no my problem do you know
By chummygyn in forum Service & RepairReplies: 1Last Post: 04-24-2006, 04:43 PM -
'04 XLV ballast problem
By kcsideways in forum Service & RepairReplies: 2Last Post: 01-19-2005, 05:07 PM -
Skeg problem...
By jon_n_andrea in forum Service & RepairReplies: 3Last Post: 02-20-2004, 01:52 PM -
problem
By in forum General ChatReplies: 0Last Post: 06-30-2003, 06:20 PM
