Results 1 to 2 of 2
    Aug 2008
    Cottage Grove, MN
    Default Hump on inside of hull in battery compartment
    In post #3 of this thread, http://moomba.com/msgboard/showthread.php?t=8354, brain installed the eznets on this hump. I just wanted to confirm that you can drill and screw into this without damaging anything? This doesn't go into an area that involves water does it? Thanks.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Jun 2009
    South West Colorado
    It is there to allow airflow from the intake down into the hull and back to the engine area. I did the same as brain and installed the eznet on there. No problem.
