Results 1 to 6 of 6
Thread: LED Trouble
    Jun 2010
    Tony Wisconsin
    Default LED Trouble
    Tried to wire up some led lights in the cup holders. They are wired in a series starting from the battery back around towards the drivers seat then into the Aux switch. Then to the bow and around. When I the switch off the ones in the back come on. When I turn the switch on they are all off. Need help
    Dallas, TX
    The LEDs need to be wired in parallel.
    Earmark Marine
    Jun 2010
    Tony Wisconsin
    so do I make my connection to the open terminal on the AUX switch to turn them on and off?
    Jul 2010
    Dothan AL
    why go from the bat to the aux switch? The aux switch should already have a power source. when i did my led's i ran them with 18ga wire from switch to driver side gunwale then back around the bow to the observer side gunwale. i joined into the wire at the cupholders in the bow, under the drivers dash and in the observers cabin.
    05 mobius ls 310hp carb
    Jul 2010
    Dothan AL
    Quote Originally Posted by gagoch View Post
    yes it should be the bottom post on the switch
    Apr 2007
    Las Vegas, Nevada
    Earmark Marine
    X's 2 wire in parallel. positive to positive and negative to negative. Wire it this way all the way down the line.
    Tazz
