I have a 2011 LSV with about 50 hours on it and for some reason the blower quit working and I cannot figure out what is wrong. I also found out that the lower blower heater setting is not working either, the high setting will work but not the low. Has anyone had this problem or know how to fix it and I checked to look at fuses but all the fuses are fine. Thanks
Results 1 to 6 of 6
07-12-2011, 01:51 AM #1
Junior Member
- Dec 2008
- Minot, ND
- 13
Blower/Lower Heater Setting Problems
07-12-2011, 07:21 AM #2
Get digital multimeter and check to see if you have 12 v at your blower when you turn it on..... this will let you know if its electrical or your blower is shot. For your heater , did you look at the wiring on the back of the switch? The low lead may have come off
09 21v LAUNCH
Doug
07-12-2011, 07:48 AM #3
Did you check your connections at the back of the switch for the heater? I actually had the lower heater connection pop off the other the day..
07-12-2011, 03:25 PM #4
07-12-2011, 05:54 PM #5
07-13-2011, 04:07 AM #6
Junior Member
- Dec 2008
- Minot, ND
- 13
Ok thanks for the input, I will try a few things and see what happens.
2011 Moomba LSV
