question, my fuel guage always shows fuel on my 02 outback. however after running on saturday for about a couple of hours, sunday it took 16 gallons of gas.
is anyone have any idea as to why?
thanks...
Results 1 to 10 of 13
Thread: fuel guage
04-18-2005, 08:21 AM #1
Senior Member
- Mar 2005
- t-town
- 713
fuel guage
04-18-2005, 09:10 AM #2
Senior Member
- Mar 2003
- Dearborn, Michigan
- 193
Replying to Topic 'fuel guage'
Use the "search" feature on this board and you will find that this topic has been covered extensively. Fuel gages are just not that accurate in boats. The factory is looking for a solution, but nothing yet. Keep track of how much fuel you add and how many hours you use the boat and start tracking it that way. Good luck.
Jeff
Dearborn, MI
04-18-2005, 12:05 PM #3
Senior Member
- Mar 2005
- t-town
- 713
i am not so concerned about being super accurate but some movement would help me determine how much i have left.
could a fuse be out causing it to stay at full.
any idea from everyone.
04-18-2005, 12:45 PM #4
Junior Member
- Apr 2005
- 17
These gauges tend to read empty before they actually are. If it is staying on full all the time it could possibly be grounded out. Either way you should take it to the dealer to have it checked out.
04-18-2005, 12:59 PM #5
Senior Member
- Mar 2005
- t-town
- 713
thank you or the info.
closest dealer is about 140 miles.
04-18-2005, 01:18 PM #6
Senior Member
- Mar 2005
- t-town
- 713
thanks jeff,
that is good info to have.
however i still want it to somewhat work....
04-18-2005, 06:40 PM #7
Member
- Apr 2005
- 48
These gauges are pretty simple. Does the gauge actually stay on full and not move at all?
04-18-2005, 06:43 PM #8
Senior Member
- Mar 2005
- t-town
- 713
wakeme,
it only moves when the ignition is turned off. other than that it says it is full all the time.
thanks for your input.
04-18-2005, 06:47 PM #9
Member
- Apr 2005
- 48
If the gauge is staying at the full mark without moving at all then you should look on the back of the gauge and make sure that the power is not grounding out. If you can, Unhook the power wire and the ground and give them power from a different source. If that gives you a diffrerent reading then thats your problem. If not, then it is either your sending unit, wire or gauge. But you can check for these other things first without taking it to the dealer.
04-18-2005, 06:58 PM #10
Senior Member
- Mar 2005
- t-town
- 713
wakeme, i will give that a try and thank you.
Wakeplate Guage
By pjtatro in forum Service & RepairReplies: 3Last Post: 09-04-2007, 11:14 PM -
Fuel Guage
By joe98684 in forum General ChatReplies: 3Last Post: 08-29-2007, 07:02 PM -
Depth Guage of choice
By Rugburn in forum General ChatReplies: 2Last Post: 07-17-2006, 03:03 PM -
Gas Guage Incorrect
By Dad The Driver in forum Boat OwnersReplies: 11Last Post: 02-28-2003, 03:06 PM
