Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Default Where is your dripless Shaft Seal cooling water T'd in?
    Curious as to where everyones driplessis T'd in? Mine was off my exhaust quick connect. It started leaking again so I T'd into the thermostat housing to rear cat exhaust dump hose as this line stays cool and was easiest. There was not enough clearance between tranny cooler drain and alternator to come off there. So far the dripless is dripless as the vesconite housing is not expanding due to hot exhaust water
    Apr 2008
    California
    Hmmm i'll have to check mine. Season four now without issue but it sure won't hurt to look either. Thanks
    Anyone here?
    Oct 2008
    On my '10 LSV it is coming from the drain plug of the transmission cooler.
    2014 Mojo Surf, might sell
    2013 Mojo Sold
    2010 LSV Sold
    2002 OB LSV Sold
    Oct 2008
    Here is a pic of the setup at the cooler. I dont know if the drain is after the cooler screen or not. I would hope so, but I have also inlet strainer before the vdrive.
    2013 Mojo Sold
    2010 LSV Sold
    2002 OB LSV Sold
    That's awesome. I see yours is tight to the alternator. Not sure if I even have that much clearance on my 09. Thanks for the pic. I have a strainer as well so I see no reason I couldn't flip the cooler and have the drain at the top
    BTW there is no screen in the tranny cooler it is honeycomb thru out so it does not matter which way it faces. Talked to indmar on this. Thanks again
    Aug 2009
    Montana
    I won't bother posting pic as I don't think the DD will help you much? But I can if you want.............
    Aug 2008
    Cottage Grove, MN
    I'm thinking about re-routing mine to the transmission cooler like McDye, as mine is currently plumbed how DOCDRS describes his. My question is: Is there a concern on how the hose is routed? If the cooling water is gravity fed, I'm assuming you have to make sure that the hose is routed so that the water does have to go up at any point. Am I thinking about that correctly?
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Jul 2011
    Murrieta, CA
    Mine is t'd into the exhaust manifold quick disconnect line. I'll probably move it one day to a cooler water source.
    I have noticed that the hot water drains out on to the prop crossbar on the trailer and has removed the paint when it drains down through he seal due to the very hot temps.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
