Results 11 to 17 of 17
    Aug 2008
    Cottage Grove, MN
    Well I did it tonight. I was tinkering in the garage and was looking at the drain thru-hull on the port side and was thinking about how to bore that hole out. I used Maxpower220's advice and put a cork in the hole, which was about a 1-1/4" hole. I needed 1-3/8" to fit the 1" thru-hull, so really not much, just a 1/16th around the whole hole.....
    I cut the stopper so that only about 1/4" stuck out of the hole, then started the hole saw (a carbide type with abrasive teeth, vs the cutting teeth) by hand. It fit snugly over the stopper so I twisted it a bit more until it met with the gelcoat. While holding a beer in one hand I just turned the hole saw by hand until I was through the gelcoat. I kept turning by hand until I was probably 1/16th into the fiberglass. Then I pulled out the hole saw and the stopper, and used sandpaper to chamfer the edges of the gelcoat. Then I reinserted the stopper, and put the hole saw in my cordless drill, and drilled very slowly until I went through. I was surprised at how thin the fiberglass was, only about 1/4". The gelcoat was about 1-1.5mm thick. Then I trimmed the carpet fibers back and that was it. Here's some pics:
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Great way to do that... where is the pic of the one inch thru hull finally installled?
    Where is the pic of the beer?
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Aug 2008
    Cottage Grove, MN
    the last picture above is the 1" thru hull. I should have stuck the 3/4" inside the 1" for the picture. The ID of the 3/4" was actually 1/2", and the ID of the 1" is 7/8", so quite a difference.
    2008 LSV - Gone
    2013 other brand
    i was expecting the chrome pic 1" looks great though. i would not have had the patience to hand turn, full power tools here.
    Tampa, FL
    Wait..... that really worked????? That's just something I made up.
    Glad it worked out. Work smarter, not harder!
    2008 Outback
    Aug 2008
    Cottage Grove, MN
    haha, it worked really well in fact.....
    2008 LSV - Gone
    2013 other brand
