    Nov 2009
    Nebraska
    Default Ballast Bag Pump Question
    I recently just upgraded my 2010 LSV with 750's in the rear. I want to be able to use my old bags in my boat. I have a pump that I used for a fat sac before it broke and it had a perfect union adapter to it. I am able to hook up the hose to fill the bag, but need something to hook the pump up when I want to empty it.
    Jun 2009
    Sunnyvale, CA
    This is what I use to with my Tsunami 1200 hand held to fill my old GIII bags now that I got the 1100's. It works well and is really a fast way to fill extra bags.
    http://www.wakemakers.com/fly-high-p...ting-w730.html
    2008 MOBIUS LSV - Acme 1847, GIII w/1100lbs Vdrive, IBS, PPSG, Wake plate, Z-5, Kenwood 700U, Kenwood Kca-RC107MR , Exile SXT65, Kicker 700.5, Kicker 350.4, Polk MM651, JL 13.5 Thin-Line Sub.
    Nov 2009
    Nebraska
    Do these pictures help? I don't know if that will fit with my pump. I can get my pump to fit in the bags to empty, but it is a pain.
    Jun 2009
    Sunnyvale, CA
    That looks like one of the rule 800 drain pumps that came stock on my boat. I put a link below that that shows the Tsunami 1200 hand held pump with cig lighter plug. The price is a little high, but if you buy all the adapters and hose to use the one you have you will probably pay for half of the new one. Plus if you ever have issues with your stock pump/impeller going bad while your out in your boat you can just use it to manually fill/empty all your bags. Be sure to get one of the adapters from the link above for each bag so it will be plug and play. And it is super fast. You won't be sorry about the performance of the Tsunami over the old pump you have.
    http://www.wakemakers.com/fly-high-tsunami-pump.html
