Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
    Jun 2009
    Sunnyvale, CA
    Question Reversible ballast pump locations on '09 or newer LSV?
    Hey guy's getting ready to start my switch to reversible Johnson pumps. I have seen a few peoples different install locations for the pumps, but I am wondering where the pumps are installed on the '09 or newer LSV with factory reversible pumps and GIII. Anybody got any pics they would like to share? I would like to make it as close to factory as possible. I really appreciate the help. I am going to try to document my process for a possible DIY thread, not that it hasn't been done already but just to show different ways.
    Thanks
    ------Sold-------
    2008 MOBIUS LSV - Acme 1847, GIII w/1100lbs Vdrive, IBS, PPSG, Wake plate, Z-5, Kenwood 700U, Kenwood Kca-RC107MR , Exile SXT65, Kicker 700.5, Kicker 350.4, Polk MM651, JL 13.5 Thin-Line Sub.
    Sep 2010
    Lake wallenpaupack PA
    Mine are on the transom wall of the starboard rear locker. There is a false wall to hide them.. you lose abour 6-8 inches of your locker
    Jun 2009
    Sunnyvale, CA
    Quote Originally Posted by lsvboombox View Post
    Thanks. Do you think you could snap a pic when you have a chance (I am mostly a visual learner)?
    ------Sold-------
    Jun 2009
    Victoria BC Canada
    Hi 08LSV,
    Sorry I haven't gotten you that wiring diagram yet. I forgot to pull it out of my glove box this morning before coming to work. Will leave a reminder in my phone so I don't forget.
    As far as mounting on the back wall, I thought about doing that but decided against it cause it will limit how full your 750's will get. I would seriously consider Jester's setup rather than mounting on the back of the transom.
    Cheers,
    Wade
    2007 Outback V
    Just curious why you are going with the reversible pump set up? Some issues with it as far as I know are much more expensive pumps, not as fast as the 1200 gph aerator pumps, and the impellers burn out if left running dry, have to mess with automatic timers to run pumps on and off.
    Seems like a well designed and executed aerator pump set up (three fill pumps, no sprinkler valves, etc) is better overall than the reversible pump set up and much less expensive. What am I missing?
    Jun 2009
    Victoria BC Canada
    Cheers,
    Wade
    Disregard as I forgot that you have an LSV so you should have plenty of room to mount on the back transom.
    2007 Outback V
    08LSV another thing to consider is these pumps take a ton of power to operate. When i was on the Wake9 boat that Wake Makers did in order to have maximum pump power the stereo was off and the engine was running. Now this might be a more extream set up then your going with but keep power in mind. If your not running 2 batteries then you should upgrade to it and you will need to be more carefull if you fill and drain while resting for swimming. Just some thoughts, but im very interested in following your thread to see what you come up with. Im at a point where i have to upgrade my ballast system. I have over bags it so bad it literally takes 30 minutes to fill and drain. Thats too long in my book lol.
    Sep 2010
    why would moomba go to the reversible pump system if the aerator pumps are a better system and much cheaper?
    2 things i disagree with are
    the impellers burn out - they are on timers and if my pumps arent pumping water they shut off before they would time out
    having to mess with automatic timers to run pumps on and off- this takes seconds to setup and you can time a perfect fill and perfect empty
    I think to get away with all the primming problems the Airators do have. Its very frustrating as a new owner when your ballast doest fill or drain and you take it to the shop to have them tell you its an air pocket and it will work its self out. Also im sure this few hundred dollars upgrade helps to support the 10K upgrade in price as the new modle that had them came out.
    Jun 2009
    Victoria BC Canada
    Bingo on the airlock issue. Heck, I've had that problem with my hand bomb Tsunami pump when it came time to drain.
    2007 Outback V
