Results 1 to 5 of 5
    Commerce Lake, MI
    Default Fat Sac and Pump deal at Red Tag Sports $199 pump plus 2 x 800lb bags.
    http://www.redtagsports.com/?avad=2872_b1fb0dd3
    Wakeboard Wakesurf Fat Sac Ballast 1,600lbs Combo + Pump
    Weight you boat out with 2 800lbs bags. This combo gets you to 1,600lbs on the cheap and quickly. This combo includes two 800lbs bags and a sumo pump. NOTE: Make sure to check the weight limit for your boat as going in excess could sink it. Pump The most powerful ballast pump on the market! Key Features of The Straight Line Sumo Pump:
    Fills 100 Pounds in 55 Seconds
    9 Foot, PVC Armor Hose will Not Kink or Crush
    12 Foot, Fused 12V Power Cord for Easy Access Anywhere
    Bag 1Launch Pad 800 Lb Ballast Bag Single If you're looking for a ballast bag that you can trust that not only looks great but does its job well, look no further than the Launch Pad 800 Lb. Ballast Bag Single. This ballast bag is designed to provide the user will all of the weight that they need in order to perform at their best. So if you're looking for a great ballast bag that won't let you down when you need support the most, the Launch Pad 800 Lb. Ballast Bag Single may just be what you're looking for. Key Features of the Launch Pad 800 lb Ballast Bag Single:
    Where To Use: The Single XL is the largest bag in the Launch Pad line, making it perfect for rear lockers, or anywhere else 800lbs. of weight is needed.
    Link System: A leak free connector with a spring-loaded flap that is air and water tight means no gushing water when removing the pump.
    Rugged Construction: Designed for years of use, Launch Pad ballast products feature a tough protective outer layer for leak free durability.
    Molded TPL Handles: Now you can easily move your bags around where you need them with these molded in handles.
    Square Design: A square outline maximizes ballast capacity and space utilization, while minimizing any rolling that may occur.
    Dimensions: 24" x 24" x 50"
    2004 Moomba Mobius LS
    Jun 2011
    Raleigh, NC
    Can you hook a tsunami pump up to these?
    2003 Mobius LSV Gravity Games
    Total Noob running 1100 in the center, 750s in the lockers.
    JL JX360/4 powering 6 Infinity 621m speakers
    Feb 2009
    Wausau, WI
    Quote Originally Posted by bkearney View Post
    I don't think they will directly hook up without the use of an adapter. Particularly if your tsunami pump has a Fly High fittings on it.
    Matt
    Jun 2009
    Sunnyvale, CA
    A tsunami will fit if you get the waterbed adapter at wakemakers to fit it. Call Jason at wakemakers and he can set you up with what you need to make it work. The problem with those bags is that they are not as tough and can get punctured very easy. I have had friends with these and they are always trying to patch them up. I would urge you to avoid the cheap bags, you get what you pay for and could you imagine if 800lbs of water just dumped out in your boat? The 750lbs real "Fat Sacs" are only $149 each. All of a sudden that extra $50 bucks a bag doesn't sound so bad if it could have prevented it...
    ------Sold-------
    2008 MOBIUS LSV - Acme 1847, GIII w/1100lbs Vdrive, IBS, PPSG, Wake plate, Z-5, Kenwood 700U, Kenwood Kca-RC107MR , Exile SXT65, Kicker 700.5, Kicker 350.4, Polk MM651, JL 13.5 Thin-Line Sub.
    Vicksburg, MI
    You might want to read this before you buy:
    http://www.wakemakers.com/launch-pad-800-single.html
    They no longer make these because of past issues of breaking. The new ones for 2011 are different.
    Joe
    2014 LSV
    2010 Outback V - Sold
