Results 1 to 3 of 3
    Dixon, IL
    Default Heater Craft Questions
    Hey guys, what all would I have to purchase to make this unit work on my boat, if it will work at all (85 Supra). I'm considering purchasing this using the skidim.com promo code that just popped up.
    http://www.skidim.com/prodinfo.asp?number=H-202
    Mar 2008
    Vancouver WA
    The fan is the other expensive part, other than that you'll need:
    Water hoses to and from the motor
    threaded barb fittings or "Y" for the motor
    Switch
    Heater hoses (hot tube if desired)
    Vents
    Really you need the whole kit to make it work. Unless your buying the core as a replacement, it won't do you any good.
    PWI as usual...
    Dixon, IL
    Alright, that's kind of what I was wondering
