Brian, I started my 99 outback ls yesterday for first time this year and the tach started jumping around and eratic as well as the speedo's as i started increasing speed, then I noticed water under dash on floor and the tach, hour meter and speedo's went dead.
Check water source and it was from the housing where the two pick up lines join and that cover has come off/ unglued. Can i just reglue this housing?, did the rest go dead from water shorting area?or what do i need to replace? Had to idle back as water just poured out from lines. Otherwise the boat ran fine.
I thank you for your attention to this matter
doug
Results 1 to 3 of 3
06-06-2005, 12:28 AM #1
speedo's leaking tach n hour meter dead
09 21v LAUNCH
Doug
06-06-2005, 09:53 AM #2
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Replying to Topic 'speedo's leaking tach n hour meter dead'
Doug, it sounds like water froze inside of your Kysor/Medallion MDC unit and split the housing. This needs to be a water tight seal. If the speedo hoses were not removed during winterization from the MDC box, water will not drain out and may freeze. Call your dealer and explain to him the situation, also, have the barcoded # that is on the front of the unit readily available. Keep us posted. Brian Raymond
07-06-2005, 10:10 PM #3
Thanks Brian, called medallian and they sent me a new mdc, took 5 mins to swap and all is working fine. have never seen in manual or told by dealer to make sure you disconnect speedo lines from mdc unit.........anyways will be regular now and maybe squirt some antifrreze in as an added safty measure to keep o rings jubricated unless you feel that may cause a problem? Medallian guys were great and thanks again Brian
Doug09 21v LAUNCH
Doug
Tach problem
By rshea99 in forum Service & RepairReplies: 2Last Post: 07-17-2007, 12:52 PM -
Hour meter
By clark in forum General ChatReplies: 2Last Post: 04-14-2005, 10:08 PM -
hour meter / depth sounder combo
By clark in forum General ChatReplies: 12Last Post: 03-21-2005, 11:57 AM -
Hour Meter on 1997 Bommerang
By swensonsl in forum Sales & InformationReplies: 1Last Post: 09-01-2003, 09:26 PM -
Trouble With Tach
By Bobby in forum Service & RepairReplies: 3Last Post: 03-03-2003, 11:45 PM
