Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
    Quote Originally Posted by rsinger View Post
    I'm assuming, among other things, this equipment reads an on board computer which actually monitors the sensors and retains the readings in memory. Think I'm on the right track here. If it's a sensor or wiring issue, couldn't one use a volt ohm meter to take the readings? A little more time consuming and more legwork required (looking up sensor specifications).
    A cheap mans troubleshooting tool but it might help the guy out in Spain. I don't suspect anyone there would have this equipment and software. Even if he orders it, could take a while to get there.
    a digital multimeter would do the trick, call indmar and speak to a tech there , they are very helpful and will probably send email you a wiring diagram maybe even sensor resistance values if they have them They are very helpful www.indmar.com
    Thank you very "mucho"! We are looking for a mefi connector over here. There are loads of volvo and mercruiser official garages maybe they could help us. We wll also contact Indmar. The Spanish Moomba importer says that when he connected the software no problem came up. He also says that there is no "memory" as such, that he has to run the diag when the problem is happening. It doesn't make much sense to us...
    What sensors could activate the limp mode?
    Temp
    Oil pressure
    Tranny oil pressure
    Water temp
    Quote Originally Posted by Arek View Post
    Temp
    Oil pressure
    Tranny oil pressure
    Water temp
    Not all mechanics are up to snuff. Are they indmar certified? with a valid certificate? Call indmar and ask your questions. I would think water temp sensor and oil pressure would be 2 good ones . Which motor specifically do you have 340 cat? 325 mpfi? it always helps if you list it in your signature with boat model and year.
  4. #24
    Winnipeg, Manitoba
    Just remembered. Look below to see if any of this might help. I had some electrical issues last year.
    http://www.moomba.com/msgboard/showt...r-fuse-blowing
    Look for the post by Engine Nut. There's a link to some schematics.
    possible future-----2013 Mojo
    Ron
  5. #25
    May 2008
    Thank you very much to all for your helps.
    Within a month, starts the season in spain, heat returns and good weather.
    And I want to have the boat managed to date.
    I will return to Check all wiring and temperatures will look.
    I'll get in touch with Indmar to watch the video.
    I will talk about how to the problend end.
    Thanks a lot.
  6. #26
    While Indmar answers our email, we are checking the procedure to read the ECM ourselfs.
    http://www.rinda.com/acro/techmate_manual_v6.pdf
    Here it says that the PCMs are equipped with Fault History, but it doesn't mention any Fault History for the GM Mefi5 Ecu.
    Can that be right?
  7. #27
    May 2008
    This is the problem....
    DIACOM MARINE SERVICE REPORT
    07/12/2012 14:02:13
    1. VEHICLE CONFIGURATION
    Cust. Name: santi
    Engine Make: 17-38
    Engine Serial No: 1
    Model Year: 2008
    System Type: GM-DELPHI MEFI 5B CAN
    2. PERFORMANCE DATA
    Parameter Description Value Unit
    Engine Speed 672 RPM
    Calibration Checksum 796A HEX
    Desired Idle Speed 680 RPM
    Engine Displacement 5,7 L
    Coolant Temperature (filtered) 162,5 °F
    Engine Hours 337,9 hrs
    Coolant Temperature (raw) 162,5 °F
    Total Operating Time 337,9 hrs
    Coolant Sensor Resistance 434 Ohms
    Total Engine Revolutions 33750 x 1000
    Throttle Position 7,8 %
    Cause For Power Reduction No
    Desired Throttle Position 8,2 %
    Check Engine Lamp Output Off
    Throttle Sensor Voltage 1 0,96 VDC
    Check Gauges Lamp Output Off
    Throttle Sensor Voltage 2 4,08 VDC
    Low Oil Level Lamp Output Off
    Pedal position 0,0 %
    Gen Warning 1 Lamp Output Off
    Pedal position sensor 1 voltage 0,96 VDC
    Gen Warning 2 Lamp Output Off
    Pedal position sensor 2 voltage 4,10 VDC
    RPM Based Output Off
    Manifold Absolute Pressure 10,9 inHg
    Fuel Pump Output On
    MAP Sensor Voltage 1,43 VDC
    Warning Buzzer Output Off
    Baro Pressure 11,7 inHg
    TransShift Output Off
    Manifold Air Temperature -40,0 °F
    Power Train Relay Output On
    MAT Sensor Voltage 0,00 VDC
    Starter Relay Output Off
    MAT Sensor Resistance 0 Ohms
    Crank Request Input No
    Spark Advance 9,2 DEG
    Emergency Stop Input On
    Cam Angle 545,6 DEG
    Shift Interrupt Input Off
    Knock Retard 0,0 DEG
    Troll Mode Input On
    Max Knock Retard Cylinder 0 #
    Load Anticipate 1 Input On
    Oil Pressure 22,6 PSI
    Load Anticipate 2 Input Off
    Oil Pressure Sensor Voltage 1,75 VDC
    Low Oil Level Input Off
    Fuel Pressure 147,9 PSI
    OEM Engine ID 215 #
    Fuel Pressure Volts 2,94 VDC
    ECM Hardware Version 5 #
    Fuel Flow Rate 0,83 GPH
    ECM Software Revision 1 #
    Fuel Temp Sensor Volts 4,84 VDC
    ECM Software Release 20 #
    Injector Bank A Pulse Width 3,9 ms
    Twin engine CAN connection No
    Injector Bank B Pulse Width 3,9 ms
    Paired Firing Mode Off
    Battery Voltage 14,00 VDC
    Rev limit threshold 5400 RPM
    Vehicle Speed 0,0 MPH
    Rev limit within last second No
    Governed Vehicle Speed 99,6 MPH
    Cruise Off
    Governed RPM Speed 5104 RPM
    Cruise Set / Coast Off
    Variable governor input voltage 0,00 VDC
    Cruise Resume / Accelerate Off
    ETC Idle Stop / Idle Valve Duty Cycle 8,2 %
    ETC System Present Yes
    IAC Position 40,2 %
    Governor Present Yes
    IAC in Control of RPM Yes
    Canister Purge System Present No
    Octane Rating Adapt 99,6 %
    MAT Sensor Present No
    Octane Adapt Enable Off
    O2 Sensor A1 Present No
    Octane update in progress No
    O2 Sensor B1 Present No
    O2-A1 Volts 0 mV
    Actual EGR Position 0,0 %
    O2-A2 Volts 0 mV
    Desired EGR Position 0,0 %
    O2-B1 Volts 0 mV
    EGR Position Sensor Voltage 0,00 VDC
    O2-B2 Volts 0 mV
    EGR Duty Cycle 0,0 %
    O2 Sensor A1 Ready No
    EGR enabling conditions met No
    O2 Sensor B1 Ready No
    EGR output enabled No
    O2 Sensor A1 Closed Loop On
    EGR duty cycle inverted No
    O2 Sensor B1 Closed Loop On
    EGR closed loop output driver On
    O2-A1 Cross Counts per second 0 #
    EGR driver type PWM
    O2-B1 Cross Counts per second 0 #
    Load Anticipate 1 0,0 %
    O2 Sensor A1 Rich/Lean Lean
    Load Anticipate 2 0,0 %
    O2 Sensor B1 Rich/Lean Lean
    Load Anticipate 1 Enable No
    O2-A1 BLM Cell Value 0,00 #
    Load Anticipate 2 Enable No
    O2-B1 BLM Cell Value 0,00 #
    Power balance test enabled Yes
    O2-A1 BLM Cell Id 0 #
    Troll Mode Off
    O2-B1 BLM Cell Id 0 #
    Troll Mode Enable Off
    O2-A1 Fuel Multiplier 1,00 #
    Gov Mode Input Off
    O2-B1 Fuel Multiplier 1,00 #
    Reflects ETC H-Bridge Direction Open
    O2-A1 Heater Current 0,00 Amps
    Min Position Learn Pending No
    O2-A2 Heater Current 0,00 Amps
    Governor Status Lamp Off
    O2-B1 Heater Current 0,00 Amps
    Close Throttle Idle Control Mode Yes
    O2-B2 Heater Current 0,00 Amps
    In Fuel Detonation Control Mode No
    O2-A1 Oxygen Percent N/A %
    Knock present in last second No
    O2-A2 Oxygen Percent N/A %
    Monitoring For Knock No
    O2-B1 Oxygen Percent N/A %
    Misc Status Flags 0,0 #
    O2-B2 Oxygen Percent N/A %
    Bank A Downstream Temp N/A
    ETC or Governor Motor PWM 14,1 %
    Bank B Downstream Temp N/A
    Canister Purge Duty Cycle 0,0 %
    Fuel Level 99,6 %
    Governor Pedal Anchor Pos 99,6 %
    Fuel Level 1 Volts 4,98 VDC
    Warm Up Cycles Since Last DTC 2 DEC
    Fuel Level 2 Volts 4,47 VDC
    A DTC has set this ignition cycle No
    Fuel Level 1 Percent 99,2 %
    CAM W Angle 540,0 DEG
    Fuel Level 2 Percent 0,0 %
    CAM W Phaser Ref Angle 705,0 DEG
    CAM W Phaser Duty Cycle 0,0 %
    3. TROUBLE CODE STATUS
    Current ECM Codes
  8. #28
    Commerce Lake, MI
    I would look at the throttle position sensor. It's throwing a fault.
    2004 Moomba Mobius LS
  9. #29
    May 2008
    stazi, where is the throttle position sensor? How do you change?
    Somebody see something in the Parameter Description Value with faulted?.
    Thanks DOCDRS.
  10. #30
    Santi, hold on a minute.
    Before we order a new TPS, you need to check the reading again.
    Have you noticed this?
    Fuel Pressure 147,9 PSI !!!!!!!!!!!!!!
    The correct fuel pressure must be 60PSI !
    Santi, espera un momento,
    Antes de pedir un TPS nuevo, deberías volver a conectar el lector.
    Has visto esto?
    Presion de Combustible 147,9 PSI !!!!!!!!!!!!!
    La presión correcta debe ser 60PSI
