Results 11 to 20 of 24
    Tampa, FL
    There are so many problems with the data provided that it would have been better for Indmar to give the specific data of oil lost and recommend more frequent oil changes.
    Showing HP required and giving inaccurate reasons for oil breakdown make the point of oil lost less believable. So many people have questions about oil and oil issues that this isn't helpful.
    Check your oil level prior to each ride, like the owner's manual says.
    2008 Outback
    Mar 2012
    NJ
    Am I the only one that picked up on "5700 lbs of ballast, a normal load for events"?
    With 5700 lbs of ballast your boat would sink.
    2008 Supra 21V
    1,450 lbs., Gravity III ballast system
    Z5 Cargo Rack
    Stereo: Pair of Wetsounds Pro 80's, Rockford Fosgate P500-2, Kicker ZX200.4, Exile ZLD, stock Kicker in-cabins, stock Kenwood HU
    Tow rig: 2008 Slate Tundra, Bilstein 5100's (F&R)
    That is normal for the professional riders at the World Championship events
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Mar 2012
    NJ
    Wow, I've never heard of 5700 lbs of ballast. I am def. going to ask my buddy about this since he mc's a lot of the tour events. I just thought that was a typo or something.
    2008 Supra 21V
    Z5 Cargo Rack
    Calgary Alta Canada
    After talking to Mike Brendella from Mb boats last year at our local boatshow he mentioned one of there team riders,often riding/surfing behind his boat loaded with 6k ponds of ballast. Combo of water and leadshot to achieve this.
    Not recomended,but definetely the way some of the PRO's do it.
    07 Outback DD
    Jul 2009
    Granbury TX
    I've heard harley clifford runs 7000-8000 pounds in his boat. One competition I did was pulled by an x-star running 6k pounds. We ran half the summer with 1800 pounds and the second half we were running 2500 pounds and never had any oil consumption when we traded the boat in with 540 hours on it using rotella 15w-40. Has anyone read PCM's break in procedure? It is quite a bit different than indmar's and they are both chevy 350 blocks, wonder which one is better?
    Break in procedure is on p.25 I would copy and paste it if I could but it's in a weird format that wont let me
    http://pcmengines.com/ex-343/
    -2012 Supra 21v
    -2008 Mobius LSV
    Mar 2012
    NJ
    7-8k is just insane! Where the hell do they put it all! Well come to think of it, for 7-8k lbs of ballast they are probably riding behind 24 ft boats so there's more room. I'd just like to see a quick video clip of where it's all stored.
    2008 Supra 21V
    Z5 Cargo Rack
    Aug 2006
    Millington TN
    That article was based on data from an LSA engine which is our supercharged small block engine. That engine uses Mobil 1 fully synthetic 5W30 oil as specified by General Motors. The data is consistent with what we see on conventional 5.7L and 6.0L engines that use conventional 15W40 oil.
    Larry Engelbert
    Indmar Marine Engines
    "Power to the Sport"
    Check out this thread
    http://www.moomba.com/msgboard/showt...77-Got-Ballast
    Muskoka, Ontario
    It would be interesting to see the results from a used oil analysis as well. I know some oils are very good (rotella t6) and used oil analysis over and over again have shown it provides protection even over Reccomend change intervals in cars, but it would be neat to see the comparison in boats. It would be a good factor to consider.
