Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
    Feb 2010
    Canton, Ga
    Default Chrome Moomba Letters
    Anyone have a problem with these starting to peel off? After we put the boat back on the trailer yesterday, while I was wiping it down I noticed that the first M is starting to peel off already after only 29 hours. Was thinking about using 3M outdoor double sided tape to fix it. If anyone else is having or had this problem what did you use? I think that it's pretty bad they would start to peel already on a year old boat with not much usage but that may just be me...
    2011 Mobius LSV 325HP EFI
    Digital Cruise Pro, Wakeplate, Kenwood KM550U and KCA-RC107MR x2, Kicker ZXM700.5, Kicker 6.5 Cabins, 10'' Kicker CompVT sub, Wetsounds SYN 4, Wetsounds REV10s, Wetsounds WS420, Gravity VI Surf Ballast, Acme 537
    Board: '11 Ronix District 143
    Skate: Liquid Force Faction 44
    Surf: Broadcast & XXX
    Tow Rig:
    Call Scott at Atlanta Marine before you do anything.
    Since you don't know exactly what the prior owner, or dealer, may have done to/with the boat who knows why it might be coming off. I have a suspicion that someone got some sort of heavier chemical cleaner or gas on that area.
    I base this off the posts from KSmith from last year where he stated that he tried everything to get the glue residue off his boat. He had to remove the remaining letters he had after his wife peeled a few off on the guidepole. But, I agree that it seems strange to me that its coming up.
    Drew
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Aug 2010
    Acworth, GA
    Hey Nash,
    Are they pealing off clean, meaning no adhesive or foam left stuck to the boat where they are peeling back or is there some adhesive and foam still stuck to the boat when you gently lift the loose parts away from the boat?
    I had a hell of a time getting the adhesive off. Where mine peeled back there was adhesive and foam still stuck to teh boat and if the loose areas hadn't folded back far enough to put a crease in the chrome I'd probably tired to fix them. But I peeled the letters off and then fought like a rabid dog to get the adhesive and foam off. Finally used gas and plastic razor blades. Heck of a mess but it worked. I had been convinced that it was the boat rubbing up against the guide poles when pulling the boat out but perhaps there is a defect lurking there somewhere...
    I have a replacement set of the OEM letters on order from Atl Marine. Hopefully it is not a defect in the product. Too expensive to keep buying these things each year...
    Kraig - 2010 Outback V
    Feb 2010
    Canton, Ga
    Drew, I have called and left Scott two messages regarding my bow handrail issue and haven't had either call returned yet. I spoke to him one time and thats when he asked I call him back last week to setup a time where I could drop it off. I called him on Monday and then again on Tuesday or Wednesday and still haven't heard from him. I realize that they are obviously busy as the season is getting started so they probably won't be able to get back to me right away but I think a week is kinda pushing it. I will call him today and see if I can get in touch with him.
    Kraig, There doesn't seem to be any or at least very little foam or adhesive stuck to the boat. It seems to be pretty clean. We were in a hurry trying to get everything done yesterday and I didn't get to inspect it too much. I know that it is either two parts on the M or the M and O. There isn't a crease or anything so they can be reused. I think I heard those letters were $300 a side...is that right? If so and these come off I will just pull them off completely instead of paying $300 for some letters that shouldn't be peeling off in the first place. Not after ONE year of little use. I have had the boat 2 weeks and this weekend was the first weekend where we really got to use it. The boat started with 22.3 hours now it has over 30. In one weekend we put over 25% of it's total use the year prior on this boat.
    The only thing that I can think of that would possibly be the culprit here is that we did some surfing yesterday for about 2 hours or so and were leaning pretty heavy to the passenger side. So the letters were submerged and it would've been the water pressure flowing over them. But, again, with the age and lack of prior use of this boat there is no excuse for there to be something wrong with these letters or anything else with this boat...in my opinion.
    Tow Rig:
    Feb 2010
    Canton, Ga
    Update: Just called ATL Marine again and spoke with Cindy. She believes they should be able to get the Letters replaced under warranty so that is a good sign. We also talked about my handrail issue and I'm going to try and bring it in tomorrow afternoon. Hopefully they can have it all fixed by this weekend...
    Tow Rig:
    That's what I like to hear!
    Drew
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Jan 2010
    North Texas
    Gotta love ATL Marine!
    06 Supra 24 Gravity Games
    Aug 2010
    Acworth, GA
    Quote Originally Posted by dusty2221 View Post
    Indeed ^^^^
    Nash, Yeah that sounds completely different than what happened to mine. Where it is clean under the loose areas makes me think that it could have been from the install if there were small areas that were not 100% cleaned before they letters were installed.
    Aug 2010
    OC Oregon
    Mine are loose as well, they were covered under the warranty also. The new set is just sitting in my garage waiting for the old ones to fall off...
    2010 LSV
    Feb 2010
    Canton, Ga
    When I took it to ATL marine the other day I noticed that its happening on both sides. They are confident they can cover under warranty and I hope so because with the handrail repair and ballast pump reprogram I'm a little afraid of the bill!
    Tow Rig:
