Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 54
    Jun 2009
    South West Colorado
    JM, what boat do you have (sorry, I'm on tapatalk and can't see your sig)? How hard was it to take the hump out completely? I am thinking about going this same route for the sub on my 08 lsv.
    2012 xlv, no hump in the newr models. they mounted a sub to a flat board and called it free air. my polk mounted in the hump on my obv sound 100x better...compartable perfoming subs.
    Here is what I am looking at , thanks to Ian and dusty it got the brain moving...
    Any pros or cons from you expert builders.
    1.1 cu ft sealed box. Smallest footprint of the three. Best way to deal with wires
    1.15 cu ft sealed.
    2.2 cu. ft ported may have o move forward and lose three to five niches of leg room.
    Mar 2012
    NJ
    Cigars, do you have a hump? Dusty solution is a solid one but it needs the factory hump to be utilized.
    I don't think being off to the right would be that big of an issue. Also, what are you centering with as their are alot of different focal points. You will make a fascia for it so its all uniform across the front anyways. Or you could put a sub on each side Or build a storage box, LED Moomba logo, etc to offset the sub being on the right side?
    Edit: I read Votto's post above and it seems by hump I was thinking of that thing on the right that the kick panel that it screws into but I am guessing no, it seems there's an"actual" hump on some models.
    Mine is open like Votto's.
    I have a Supra so I wouldn't be putting any LED Moomba logo on the panel. Now an LED Supra logo, hmmm, might be tempted.
    2008 Supra 21V
    1,450 lbs., Gravity III ballast system
    Z5 Cargo Rack
    Stereo: Pair of Wetsounds Pro 80's, Rockford Fosgate P500-2, Kicker ZX200.4, Exile ZLD, stock Kicker in-cabins, stock Kenwood HU
    Tow rig: 2008 Slate Tundra, Bilstein 5100's (F&R)
    looks like i am going with option one or a similar version.
    Dang this exile sub is niooce!! 12 DVC 12xi
    Dixon, IL
    jmvotto, I may have missed it earlier in this thread, but what materials are you using to construct the box?
    Jan 2010
    North Texas
    My, what a beautiful sub you have there.
    06 Supra 24 Gravity Games
    3/4 mdf and seal it will a couple coats of resin inside and out , then carpet it grey to blend in.
    BOOM BOOM POW baby.
    6 SX65M Cabins
    6 XM9 Towers
    1 XI 1K Harpoon
    2 XI 800.4
    1 XI 2500.1
    Traverse City, MI
    MDF will soak up water, no matter how much resin you coat it with. My first box had a full gallon of resin inside and out and it still got destroyed by water. I would (and did) go with a nice ply, like Birch.
