Results 1 to 10 of 16
    Jul 2011
    SE MI
    Default Help... OEM Chrome Logo Measurement...
    Can someone who has the LSV chrome logos from the factory help me out w a couple of measurements? I have finally worked up the courage to put em on but cant seem to figure out if the sides run parallel w the rub rail... What I need is a measurement from the first point of the first "M" to the bottom of the rub rail... And then the point of the "A" to the bottom of the rub rail... And then same thing for the m and s in mobius at the back... Thanks in advance!
    I don't think that's going to work too well. The hull curves in at least 2 directions and so does the rail. You may be better off getting someone with an artistic eye to help you place them. Use the green masking tape and stand back till everything looks perfect. Go online and search 2010 or 2011 LSV and look at 30-40 pictures of the letters. You'll get a great feel for where they go. You'll also notice they place them in slightly different positions based on which tower is on the boat and whether it has a wrap. Figure out what looks best on your boat. I have an artistic daughter who helped place mine (but my letters were no good so I had to take them off -- but they were placed right.) Good luck!
    Jul 2011
    SE MI
    I hear what you are saying but I thought if I had a measurement I would at least have a starting point...
    I have looked at a bunch of pics and the logo looks like it follows the rub rail but I am not sure... This is the one I am trying to look like... I actually think he is on the board but I found this on WW
    Feb 2010
    Canton, Ga / Lake Lanier
    Here is another...
    2011 Mobius LSV 325HP EFI
    Board: '11 Ronix District 143
    Surf: Broadcast & XXX
    Tow Rig:
    Belton, Texas
    That's stangkillas boat.
    Sent from my home phone..
    2009 Moomba Mobius LSV
    Jul 2011
    SE MI
    Any chance of getting a measurement or 2 E4Nash?
    Feb 2010
    Boat is in storage until Friday at the earliest. I can see about getting a couple then.
    Tow Rig:
    Jul 2011
    SE MI
    Thank you. I was hoping to get this going sometime this week... If I dont hear from anyone by Friday I will let you know if I need you to go to the trouble...
    Feb 2010
    Quote Originally Posted by eblom View Post
    FYI - When you do put those stickers on be careful when you are peeling the backing off. Apparently they've had a problem with the backing actually pulling the adhesive and part of the "foam" part of the decal off. I just had both sides replaced under warranty and one side they had to do twice because the first one that was sent messed up when the backing was peeled off so the dealer had to order another one.
    Tow Rig:
    Jul 2011
    SE MI
    Thanks for the tip... I only want to do this once lol...
