I just got a new 2003 outback. When you step on the swim platform pad then get back in the boat it leaves black s*%t all over the vinyl. Does this black residue eventualy go away???
Results 1 to 10 of 14
Thread: swim platform pad
04-03-2003, 02:34 PM #1
Junior Member
- Apr 2003
- 1
swim platform pad
04-03-2003, 05:05 PM #2
Senior Member
- Jun 2002
- Lake Mayo NC
- 186
That never happened with my new Outback
04-03-2003, 11:01 PM #3
Junior Member
- Mar 2003
- Arizona
- 4
Swim platform pad
I have an 02 Mob LSV and it does the same thing. Noticed it when I took the boat on a demo. My dealer is replacing the pad under warranty with the new type of material that Moomba and Supra are useing. Actually they just called me this week to let me know that the part came in. That stuff is hard to clean and can stain your vinyl. They should replace yours also.
You better slide a little gas money this way!
04-22-2003, 02:17 PM #4
Junior Member
- Jun 2002
- Alabama
- 16
swim platform pad
I have a 2002 Outback with the same problem. It occurred last summer, and happened yesterday as well when I de-winterized the boat. Evidently the sun causes the dye to break down, and when it gets wet, you track it right onto your upholstery and carpet. Good thing is that I've always been able to wipe it right off, without leaving any stains. Also, scrubbing the pad down with soap and a good stiff brush, and rinsing thoroughly seemed to help, but you'll have to do it periodically over the summer, as the black slime will come back after a while.
04-24-2003, 08:24 AM #5
Senior Member
- Mar 2003
- Dearborn, Michigan
- 193
I am waiting for delivery of my 2003 Outback LS, do I need to be concerned with this happenning on my new boat? Or is the change in the pad material going to cure the problem? Is there a material change for all the new boats minus the std. Outback? Any advise is appriciated. Thanks.
Jeff
Dearborn, MI
04-24-2003, 01:18 PM #6
Platform pad
I have a 2002 outback, I have about 20hours on it from last summer, I never noticed any dye comming off and tracking onto the boat. Maybe some of the cleaner you are using is breaking down the dye and not the sun? Harsh chemicals will pull the dye from the material and cause it to break down quicker than UV rays.
2002 Moomba Outback Red
04-25-2003, 05:36 PM #7
Junior Member
- Jun 2002
- Alabama
- 16
Mine actually started bleeding right "out of the box". First time I climbed out of the water, it tracked right onto the upholstery. I thought it was just because it was new, and would soon stop (like washing a new pair of jeans). If it keeps doing it this summer, I'll have it replaced.
10-16-2003, 05:23 PM #8
Junior Member
- May 2002
- Eau Claire, WI
- 4
Same on original and replacement
I had the same problem on an 03 Mobius LSV. We replaced with the newer material and have the same problem. A good pressure washing helped reduce it for a while. I miss the old grey material. I am waiting for Moomba's next move. I have heard good things about gator grip and may give it a shot.
10-16-2003, 05:33 PM #9
Senior Member
- Apr 2003
- Powhatan, VA
- 316
Old grey material --- I assume you mean the stuff on the older model boats --- it works great! 5 seasons, no issues.
10-17-2003, 08:52 AM #10
Member
- Mar 2003
- Mississippi
- 67
Yes, this is a common problem. The orginal pad is soft and breaks down. The replacement pad is a harder rubber which works better. They replaced mine under warranty.
Swim Platform Help
By JesseC in forum General ChatReplies: 26Last Post: 11-07-2010, 08:14 PM -
swim platform
By blainb in forum Moomba ClassifiedsReplies: 2Last Post: 10-25-2005, 12:23 PM -
Swim Platform pad
By weirdo0521 in forum Boat OwnersReplies: 11Last Post: 06-19-2005, 04:56 PM -
swim platform
By blainb in forum Moomba ClassifiedsReplies: 0Last Post: 07-15-2004, 01:34 AM -
Anyone want to buy my swim platform?
By barefooter in forum General ChatReplies: 5Last Post: 07-02-2003, 08:33 AM
