What do you use to glue them in??
I'm sure it's been addressed 29 times already.
Thanks.
Time for a surf sac
Results 1 to 10 of 19
Thread: Fat sac glue question?
06-24-2012, 12:19 AM #1
Brad
Mississippi/Louisiana
2011 Launch 21V
2006 Moomba Mobius LSV sold
2004 Outback sold
06-24-2012, 12:36 AM #2
Do you mean the fittings? I didn't glue mine in at all, just tighten them up. Knock on wood, no leaks.
New ride: 2012 Mojo
Old ride: 2008 OBV
06-24-2012, 01:29 AM #3
Yes, fittings.. Thks for reading my mind
Brad
2011 Launch 21V
2004 Outback sold
06-24-2012, 02:27 AM #4
I've used just some pipe tape. Others suggest the pipe dope stuff or the pvc cement. If you ever want to get them out you might think about how permanent you want it. It's low pressure so I don't see why you need anything but the pipe tape works great.
06-24-2012, 05:31 AM #5
Wakemakers recommended all purpose pvc cement. I have a port that is leaking enough that thread tape won't fix it so I'm planning to give this a try.
06-24-2012, 08:34 AM #6
Just hand tighten, leave glue for last resort, Teflon tape is 2nd step.
06-24-2012, 10:25 AM #7
Went with tape. Wasn't up for the glue. We'll see how it holds
Brad
2011 Launch 21V
2004 Outback sold
06-24-2012, 12:16 PM #8
I think taco beat would weld them in... but that's just a guess
Kraig - 2010 Outback V
06-24-2012, 12:46 PM #9
I tried both methods. Only the PVC glue held for me. The downside is that the fittings may be permanent. But - no more fittings popping out and sending 400 lbs of water onto the carpet and into the bilge.
2010 Moomba XLV
340hp cat
Gravity 3, wake plate
Rad-a-cage
1100 surf side v-locker
650 in the floor locker
600 to move around
06-25-2012, 10:16 PM #10
Senior Member
- May 2010
- Muskoka, Ontario
- 363
I dont see how the fitting could pop out. When I installed mine on the 750's it was a real stretch to get them in all the way.
On another note I want to take them off on the OEM 400 bags. Does heat help? They are on there good, not sure if Moomba puts glue on them from the factory.
