Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Feb 2010
    Canton, Ga
    No amp? Is it a Kenwood radio?
    Even if you did have to wire it up it's pretty easy. All of the wires from the new HU are labeled. They should be on the old one too. Just disconnect the harness from the stock radio and take the old HU out. Then, disconnect each wire one at a time from the old harness and connect it to the new one. The color scheme should be the same or at least they should be labeled like Front +, Rear -, etc...
    If you are running all 6 speakers off of the head unit it may be cutting out at the high volume due to the ohm load. You should look into getting a 4 channel amp to power your inboats and free up your radio...
    2011 Mobius LSV 325HP EFI
    Digital Cruise Pro, Wakeplate, Kenwood KM550U and KCA-RC107MR x2, Kicker ZXM700.5, Kicker 6.5 Cabins, 10'' Kicker CompVT sub, Wetsounds SYN 4, Wetsounds REV10s, Wetsounds WS420, Gravity VI Surf Ballast, Acme 537
    Board: '11 Ronix District 143
    Skate: Liquid Force Faction 44
    Surf: Broadcast & XXX
    Tow Rig:
  2. #12
    Waterloo, Ontario
    i dont think theres an amp anyways, i dont see one.. i don't have tower speakers.. and yes its the kenwood.
    would i have to get someone to install the amp?
    2006 Moomba Mobius LSV
    Lake: Rice lake, Ontario
    Stereo: Kenwood KMR-550U
    Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
    Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"
    If you're from the area and want to surf, send me a PM!
  3. #13
    Feb 2010
    Canton, Ga
    Either you can install it or you can have a shop do it. Installing an amp isn't really difficult, the confined space of a boat makes it a little less than fun though. If you can install a ceiling fan or light fixture then you can install an amp.
    Tow Rig:
