Hey all, I know I may be asking alot, but does anyone with an 05' LSV have a sub under the drivers seat that they can measure. The space under there doesnt look like it can hold a 10 or 12 inch unit. Maybe I should take it somewhere & have them look at it, and put in a custom setup. Specs, or thoughts appreciated
Thread: Sub woofer specs?
07-05-2005, 09:00 PM #1
Senior Member
- Mar 2005
- 109
Sub woofer specs?
07-07-2005, 10:18 AM #2
Member
- Mar 2004
- 34
Replying to Topic 'Sub woofer specs?'
I have a 12 inch rockford fosgate sub in mine in a 1.75 cubic ft "truck box" It is made to fit behind the seat of a standard cab truck.
07-07-2005, 10:32 AM #3Guest
I have a 10" Kenwood marine sub installed in the kick panel in front of the drivers seat. It is model #KFC-W254MR. I push it with a 350 watt Kenwood amp and it sounds really good. I don't think a 12" sub will fit in there because my 10" goes from top to bottom on the panel. Hope this helps.
07-07-2005, 10:34 AM #4
Member
- Apr 2003
- Ky
- 63
I have a 10" Kenwood marine sub in mine, model # KFC-W254MR. I run it with a 350 watt Kenwood amp and it sounds really good. I don't think a 12" sub will fit in the panel since my 10" sub covers it from top to bottom. Hope this helps.
07-09-2005, 09:26 PM #5
Junior Member
- Apr 2004
- 20
I am running two ten inch Kicker Comps under my steering column...I have them hooked up to a 600 watt Kicker amp. I am also running 2 co-ax speakers and 2 mids off of an 800 watt Kicker amp. Plenty of power and have not had any troubles with the boats electrical system after the install.
Although the bass did rattle the pins out of my coupler!!!
Steering cable specs for 05 LSV.
By millerthymes1 in forum Service & RepairReplies: 7Last Post: 10-18-2007, 08:52 AM -
98 outback specs
By schwartzman in forum Sales & InformationReplies: 1Last Post: 10-03-2006, 12:42 AM -
Re: Sub woofer in 2006 lsv
By mschude in forum General ChatReplies: 4Last Post: 07-18-2006, 02:20 PM -
Technical Boat Specs
By jon_n_andrea in forum Service & RepairReplies: 0Last Post: 03-20-2004, 10:27 AM
