Anyone have some pictures of how they installed their EQ or ZLD under their dash? I've been searching the forums and found one post but the link it refers to has been removed.
Thanks in advance!
Wade
Results 1 to 10 of 42
Thread: EQ Install Advice
06-19-2012, 02:23 AM #1
EQ Install Advice
2007 Outback V
06-19-2012, 06:14 AM #2
Wade, on the obv I put two l brackets on the steering column bolts then added some lock washers an nutsthen screwed some plastics board a tad bigger than the eq to the brackets. Then just mounted the eq to the board flush to the board. Its only place I could find to mount on the obv, not enough dash board anywhere else.
Check out my profile pics.
JoeA Day at the Lake...Priceless
06-19-2012, 06:47 AM #3
Wade - I ran into a similar problem this spring. I followed JM's instructions as indicated above. Worked great. All you need is a couple L brackets from Lowes, nuts, washers, and a "board" cut so size. I thought I would have some starboard left over from my amp rack but unf. I didn't. I went to Target and picked up one of these and cut to size: http://www.target.com/p/superboard-p...4x17/-/A-85899
IMG00005-20120506-2017.jpg'06 Outback - Gone but not forgotten
'13 Mojo
06-19-2012, 07:26 AM #4
Senior Member
- Jun 2008
- 106
I mounted mine below the throttle by the gravity III switches. With a trim piece from a stereo place, it looks pretty clean and its at your finger tips for volume control.
2008 Outback V with closed cooling
Gravity III upgraded to 750's in the rear
Wetsounds Pro 80s with Kicker amps for boat and tower
RF Punch Sub with Alpine amp
06-19-2012, 09:12 AM #5
Senior Member
- May 2010
- Muskoka, Ontario
- 368
I just ended up doing my krypt eq this past weekend.
Did what was suggested above. Cut a piece of 1/2 inch plywood just slightly wider than eq, bolted it below the oem switch panel on right side with 2 L brackets, mounted eq to board and also attached a piece of wire to the board near the rear to stop any movement up and down on big waves etc, it's solid.
06-19-2012, 09:30 AM #6
here is the pic
06-19-2012, 10:25 AM #7
06-19-2012, 10:51 AM #8
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
06-19-2012, 10:53 AM #9
Senior Member
- May 2010
- Muskoka, Ontario
- 368
that looks good! on our 2010 i dont think i have the room under the switches to do that though
06-19-2012, 10:55 AM #10
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
