Results 11 to 20 of 42
    Yeah you have to start with a blank panel. Here is the PM I just sent Mike:
    I removed the old panel by popping out each of the switches one by one, hooking them back up behind the panel so I didn't forget how they were wired. Once the panel was free I used it to make a paper template. I just moved the row of switches higher up but kept them "level" with the stock alignment. The EQ hole I just measured and kinda guessed, erroring on the side of "too small" then filed it just big enough to fit.
    You have to buy a blank and move the switches up. i have a blank i was trying to contact Brain for any tips before i break out the dremmel. I will take some pics and do a write up if i can get this done LOL.
    The dremel worked pretty well and didn't chip the finish at all. It just sort of melts through the plastic though so it's an interesting process. I might try one of those vibrating trim saws if I were to do it again.
    If you have your panel off you could think about wrapping it (and the key side, maybe even the gauges) in some custom vinyl, maybe some of the 3D carbon fiber. I would have done this if I couldn't source a blank panel and had to reuse the factory one or fabricate my own.
    Jun 2009
    Victoria BC Canada
    here is the pic
    Thanks JM, that's exactly what I was looking for!
    Need to climb back under there to see how the L-brackets would attach. How long are these L-brackets anyway?
    Cheers!
    Wade
    2007 Outback V
    Pacific Northwest
    Here is what I used.
    Here is how I attached it. Both sides.
    And here it is finished. Easy, cheap and no fabricating.
    2004 Moomba LSV Blue
    Pacific Northwest
    Another pic of it.
    Sep 2010
    Mckinney, TX
    Same problem diff boat. Our older supras dont have a FLAT under dash. Its wavy and drops down at the wheel. Anybody have any ideas or pictures for that??
    89' Comp Resto:
    Riding and Mod pic's:
    Jan 2010
    North Texas
    How about you provide us with pics so we can make suggestions?
    06 Supra 24 Gravity Games
    why don't you head down to his house, see it for yourself and help him get his boat on the water?
    New ride: 2012 Mojo
    Old ride: 2008 OBV
    Jun 2009
    Victoria BC Canada
    Quote Originally Posted by bbuhtz View Post
    here is what i used.
    here is how i attached it. Both sides.
    and here it is finished. Easy, cheap and no fabricating.
    like button!
    2007 Outback V
    Ditto that ^^
    As long as it stands up to the bumps that is exactly where/how mine is going too! Just got my cables from Monoprice the other day so now it's go time!
    2001 MobiusV
