Yeah you have to start with a blank panel. Here is the PM I just sent Mike:
I removed the old panel by popping out each of the switches one by one, hooking them back up behind the panel so I didn't forget how they were wired. Once the panel was free I used it to make a paper template. I just moved the row of switches higher up but kept them "level" with the stock alignment. The EQ hole I just measured and kinda guessed, erroring on the side of "too small" then filed it just big enough to fit.
Results 11 to 20 of 42
Thread: EQ Install Advice
06-19-2012, 11:08 AM #11
06-19-2012, 11:12 AM #12
The dremel worked pretty well and didn't chip the finish at all. It just sort of melts through the plastic though so it's an interesting process. I might try one of those vibrating trim saws if I were to do it again.
If you have your panel off you could think about wrapping it (and the key side, maybe even the gauges) in some custom vinyl, maybe some of the 3D carbon fiber. I would have done this if I couldn't source a blank panel and had to reuse the factory one or fabricate my own.Last edited by brain_rinse; 06-19-2012 at 11:15 AM.
06-19-2012, 12:11 PM #13
2007 Outback V
06-19-2012, 01:05 PM #14
Here is what I used.
Here is how I attached it. Both sides.
And here it is finished. Easy, cheap and no fabricating.
2004 Moomba LSV Blue
06-19-2012, 01:08 PM #15
Another pic of it.
06-19-2012, 01:47 PM #16
Same problem diff boat. Our older supras dont have a FLAT under dash. Its wavy and drops down at the wheel. Anybody have any ideas or pictures for that??
89' Comp Resto:
Riding and Mod pic's:
06-19-2012, 01:49 PM #17
How about you provide us with pics so we can make suggestions?
06 Supra 24 Gravity Games
06-19-2012, 02:49 PM #18
why don't you head down to his house, see it for yourself and help him get his boat on the water?
New ride: 2012 Mojo
Old ride: 2008 OBV
06-19-2012, 04:00 PM #19
06-19-2012, 05:33 PM #20
Ditto that ^^
As long as it stands up to the bumps that is exactly where/how mine is going too! Just got my cables from Monoprice the other day so now it's go time!2001 MobiusV
