Results 21 to 30 of 31
    Belton, Texas
    Are standard hockey pucks the right size?
    What kind of puckin question is that and how the puck is he suppose to know the puckin answer to that. -
    Sent from my home phone..
    2009 Moomba Mobius LSV
    Apr 2012
    Wake Forest, NC
    This is puckin crazy. Measure the cupholders, cut some PVC and epoxy it to the bottom of the cushion. But what the puck do I know?
    2008 Outback V
    Belton, Texas
    ^^^ need a like button.
    This puckin thread is so far off course it's just plain puckin funny
  4. #24
    You Mother puckers better be real pucking careful or ole' RD may just decide to puck you up.
    2015 Supra SG
  5. #25
    Feb 2010
    Canton, Ga / Lake Lanier
    Shut the puck up and go to pucking bed!!
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  6. #26
    This pucking thread has just gone straight to H, E, dbl-hockey sticks.
    2015 Supra SG
  7. #27
    I tried to build a pucking tower camera mount out of PVC and had no pucking luck finding the right size!
  8. #28
    Jun 2009
    South West Colorado
    Can you post up more info on the wind block?
    Ok, a few more photos of the wind block.
    I used 1/2" hdpe (cutting board type product) and had to spend some time carefully measuring and cutting to get the tapered shape (top to bottom) correct in the opening when closed.
    A simple set of stainless hinges works perfect.
    Simple slide bolt that slides into a hole drilled in the drivers side wall and a rubber grommet superglued in to stop it from rattling.
    Lastly, I used a router to round off the outside edges so it does not hurt too much if you catch it on the way to the bow.
    It fits perfect under the center window when closed and really cuts out the wind. (see photo from the beginning of thread).
    One of the best mods I have done- according to my wife...
  9. #29
    Thanks!.....
    2006 Moomba Mobius LSV
  10. #30
    Feb 2013
    Friendswood, TX
    Is it sturdy enough for a passenger in the center position to lean against?
